another welding question
Discussion in 'The Garage' started by Brian85gmc, Sep 11, 2002.
  1. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    Can I weld body panels with an arc welder(18 gauge), or do I need a mig?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I say good luck with the arc welder. The heat ranges generally don't allow you to get low enough where you won't burn through. If you do manage to get a piece of metal to stick to the side of your truck with it, you'll be using a lot of bondo to patch the holes created by the heat of the welder.
    A mig, wire-feed welder is the best option.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I would definitely use a wire feed.
  4. GrimWheeler
    GrimWheeler Registered Member
    Feb 22, 2002
    44
    Eugene OR, USA
    I would have to say... it all depends on how good you are with stick. I've had to weld 16guage down hill with 7018 before.. of course it doesn't turn out all that pretty (definetly not autobody "pretty") but it can be done. I guess it all comes down to how pretty you want it.. I would go with the suggestion of using wire. I used .030 when I did the bed bob on my truck ... if you want it really pretty, make sure to use master mix (nitrogen/co2).
    Here is a picture of how it turned out.. after paint.. now remember.. I'm not an "autobody" guy either
    OH yeah.. almost forgot.. that 3" wide Ford spring swap I've been reading other people taling about.... hehe I did that April of last year on my truck.. gotta love it.. (and my "phat" shackles too) /forums/images/icons/wink.gif
    Brian
    http://i.am/GrimWheeler
