Another "Whats this" question!!
Discussion in 'The Garage' started by dallassnowman, Mar 27, 2004.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Another \"Whats this\" question!!
    My speedometer is jumping all over because of this.
    Already replaced all cables, jacked up the rear and looked at this without the cable hooked up that goes to my speedo and I can see its jumping, not turning smoothly! /forums/images/graemlins/confused.gif
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Re: Another \"Whats this\" question!!
    thats the cruise control
    did you change both cables..cable from trans to cruise control unit..cable from cruise unit to speedo? if so,
    maybe just need to pick up another unit from the old pick n pull...
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats for the cruise. the older setup up to 82 or so
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That would be cruise control. Unplug the wires and see if the jumping stops. If so you can go straight from the t-case to the speedo (bypassing the cruise). I can't figure out the vacum system in mine to totally remove it.
  5. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    Like everyone else has said already, its the "AC CruiseMaster" cruise unit. Another thing to try to make sure it is indeed that part, is to unhook your cable at the case, then hook up a cordless drill to the cable itself, run in reverse mode, and watch the speedo-does it move, and how well? If it runs at a steady 10-15mph or so (about max speed for my 18v cordless), chances are your cruise unit is good-if this is the case, go back to the adapter going into the case and replace that little "key" piece that connects the driven gear in the case to the actual speedo drive gear, making your speedo turn. Those tend to fail more often than the actual cruise unit.
    However, the units themselves are prone to a magnetic problem which will cause them to seize entirely-if that's the case, and with the drill, you have no movement at all on the speedo, replace this. It's about $50 or so if I remember right from your local parts store-somewhere in that neighborhood anyway.
    If your problem is more of a bouncing speedo while driving, maybe rests at a given speed, then will suddenly jump and bounce around, that's the actual "key" itself down by the case. Again, they fail quite often, but luckily are cheap and easy to replace. Another thing to try, even though you have already replaced the cables, is to lube them with a good graphite. If you can find the old style can that fills with graphite, runs off your air compressor and a drill-those work best. Basically the air blows graphite up through the can into the speedo cable line, as you run the drill, thus spinning the cable and drawing the graphite up to the other end. They work great, but are hard to find anymore. Even new cables occassionally need a little lube work.
    Hope this helps, and Best of Luck,
    Mike
  6. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Wow thanks for everyone's response. The cordless drill idea is a good one I'll try that in the morning. Im pretty sure its the cruise unit itself. When i raised the rear end up I put it in drive and watched the speedo turn then unhooked the cable going to the tranny and it wasnt jumpy there.
    I love this web site IT'S LIKE HAVING MY OWN LIBRARY ON K5's!!! /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
