Another where can I find thread.....Found a Solution
Discussion in 'The Garage' started by fabjunkie, Aug 5, 2006.
  1. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Just realized today that the 14ff that I'm putting in the Blazer is missing the tube for the breather hose. What exactly is it that is supposed to be there and where can I get one? Or can I tap the hole and put a screw in piece in there?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If you are just missing the rubber hose, then goto the part house and get an oil/gas resistant rubber hose of whatever length you want.
    If your missing the actual mount that the rubber hose hooks to on the housing, just then tap the whole and thread in a brass nipple to hook the hose too. If you do this, I would pop the cover and put tape over the hole to collect the threading chips.
  3. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    No, I have the hose, which was attached to the housing, but whatever it's supposed to be hooked to isn't to be found. :confused: Can you get a screw in nipple in straight thread, or are they all NPT? I thought about finding some brake line the right size, cut a small peice and press it in. Don't know how well that would hold up though.
  4. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I had to install a fitting in mine and just tapped it in. I also extended all the lines on the truck all the way to the engine area except fot the rear Diff.
  5. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Just an FYI for anyone with the same problem or wanting a good stout way to mount the breather hose. The hole in the housing on a 14ff (not sure of others) is just the right size to tap 1/8" NPT. Did it today and screwed in a nipple. That thing ain't coming out now. :D
  6. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Ditto. did the same thing.
