Antenna Booster
Discussion in 'Audio' started by dhcomp, Mar 25, 2001.
  1. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    I am going to install a new head unit when i get a Blazer, and i was wondering if these Antenna boosters are any good. go to http://www.crutchfield.com/cgi-bin/S-1jheZXC3P0V/ProdGroup.asp?c=2&g=732&s=0 to see two. Has anyone installed these? How do they work? Do they just make it louder, or actually improve reception? Thanks!
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    i've tried a couple of these in the past with no luck... no real improvement IMO. I'd say save your money...
    1987 Chevy K5 Blazer- 350 TBI
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    They're kinda like those things from J.C. Whitney that strap around your fuel line and magically increase gas mileage. And they never really work. I haven't had much luck with the antenna boosters either. If everything is set up right (your radio and antenna) you shouldn't need one. If your antenna mounts to the body, make sure its tight and has a good ground to the metal.
    '73 K5
    Chevy good...Ford bad
