Antenna Coax Cable (Spliceable?)
Discussion in 'Audio' started by BowtieBlazer, Apr 27, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Is an antenna cable or wire whichever you prefer just like any other wire so that you can just splice right into it? I need to leangthen the antenna cable on a project I am working on. I don't just want to cut the cable and find out I can't make it work. Thanks!
  2. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    They sell an extension cable for what you are wanting to do... has a female connection on one end and a male connection on the other... Hope that helps..
  3. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    I did the same thing I ended up buying extension wires like mentioned above. I don’t know all about the but when I bought the extra wire it said that it was not possible to cut the wire and have it work correctly? I don’t know how much to belive in that but that’s what was on the package. They have spliter devices and switching devices as well. I ended up using my one antenna line to run my radio, CB, and pager system for the truck.
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    yeah I talked to a buddy its possible just difficult to splice into an antenna. Its just like cable coax. I'll go search radio shack tomorrow for some extension cable.
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Try a car audio shop they should have them for sure. We sell them for less then 5bucks on a 20 foot extension and around 1.50 for a 12 inch one.
    You can splice the cable yet I do not suggest it. There is one single pole center wire with a plastic shield; over that is usually a braided ground sheath and then the outer jacket. So you are right by saying it looks like TV cable. The extension will not hurt you any compared to a splice so go for the entensions and save yourself the heartache ;-)
