antenna for GPS?
Discussion in 'Communication (CB | GPS | HAM)' started by Marshall, Dec 16, 2002.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    I have a Garmin etrex and i was wondering if i could get an antenna and mount the gps so i can use it in my truck? If anyone knows this is possible please let me know how to do it. /forums/images/graemlins/confused.gif
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    They don't have an antenna jack so the only way to add an external antenna is to hack the case and force one on it.
    Your best bet to be able to use it in the vehicle is to get one of those mounts that will stick to the widshield and hopefully have a good enough view of the satallites to work.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My Garmin Street Pilot mounts on the dash and there is a difference. On the dash its accuracy is like 18 feet. If I hold it out the window, it goes down to 3 feet. I dont think it has an external antenna hookup either.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My Magellan 315 typically has a strong lock on 7 or 8 satellites while mounted to the windshield in my truck. /forums/images/graemlins/shocked.gif I think that'll give me enough accuracy for my needs. /forums/images/graemlins/wink.gif
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    My Garmin Rino 120 gets a strong lock from 8-9 satellites inside my truck with a windshield mount. Your unit is similar to mine in that it has no hookup for an external antenna. Also, the eTrex antenna is built in to the unit, whereas the Rino is a quad-helix. I would see how it operates inside the vehicle in the windshield area. If it retains lock, a windshield mount will work just fine.
    The GPS Store has a wide variety of Garmin GPS accessories at a lower cost than factory direct. A listing of these is here.
    Hope that helps!
    /forums/images/graemlins/burb.gif
