Antenna question
Discussion in 'Communication (CB | GPS | HAM)' started by dontoe, Feb 6, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I installed the side mount ball whith a 102" whip on the Blazer today. Problem is it sticks out like the simple drawing I made. How can I get it to stick straight up?
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I had the same problem with mine. My ball mount was a split ball that had a bolt holding the two halves together. All I had to do was rotate the halves until the antenna was straight.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, I did that to install it. If I rotate it now, it gets worse.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What do you mean it gets worse ??
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    It leans further away from the truck. There has to be some type of "shim washer" or tapered washer that would fix it.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, I never thought 'o that. I could make one of those!
    I bent the antenna for now so I don't whip oncoming trucks. campers, etc; here's some pics from just after dawn this morning.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Quick and easy would be too tie it too the topper. Use a tennis ball too keep it from making contact with the metal of the body.
  8. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    You should be able to adjust the whole ball by loosening the nut on the back of the mount. Then use the angled split of the ball to get it pointed just right.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Oh.......kool, first one I ever have messed with. Thanks man. I didn't know it would do that, obviously.
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    looks like the base itself is angled outwords, maybey use plastic washers to bring the bottom of the mount out
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    let the girlfriend massage it for a few minutes:D :doah:
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I know what happens to side mount antennas in AZ :wink1:
  13. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Use tennis ball on ant. So it is not grounding out on body when you talk. I have seen this fry a nice cobra.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [​IMG] Looking at that pic, I usely go higher with the mount. Like just below where the topper bolts on, on the pass side, differectly above rear tire.
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    i'd get rid of that big 'ol spring first, that big whip will move around enough as it is, then adjust the ball to straighten up the whip. I have heard that those springs will mess with your SWR anyways, in a bad way, or make it hard to adjust.
    And yeah, side mount antennas in AZ usually get ripped off,,,,,by mountainsides:doah: .
  16. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I figured it would get tore off, but I know where to get another. So the spring is bad????????
  17. 4xcrazy
    Oct 31, 2003
    9,471
    5
    this is what i have heard from fellow drivers, and cb shops while out on the road, make's it hard to adjust correctly, or make's the swr too high or something.
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've always ran the heavy duty (pot belly) spring with the 102" stainless steel whip and have never had a SWR problem.
  19. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have been told the spring actually helps with SWR as the extra length from the spring gets the antenna closer to be an actual 1/4 wave. 102" is slightly short.
    Ira
