antenna related contraption someone built- what is it ?
Discussion in 'The Lounge' started by R72K5, Sep 13, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i came across a piece of plywood with a couple 110volt input/ 23 volt 1 amp output power supplies and three LS-275-C 2 way splitters and three Hewlitt Packard M1407A 19-40 VDC 1 A units and a blue LS-475-C 4 way splitter on it and wired with cables such as electro wire and cable for antennas all dated 1992
    what is this contraption ?
    what are the HP units, and why the 23 volt powers ?
    anythning i could use or do with any of these ?
    thanks
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Telephone machine? :haha:
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    http://www.mdico.com/mdic/currentinventory2005w.htm
    2060 WINEGARD COMPANY 4 WAY SPLITTER LS-475C 4 EA
    2061 WINEGARD COMPANY 2 WAY SPLITTER LS275C
    http://students.kennesaw.edu/~eah2488/Documents/Magic.txt
    HP M1407A Multiple Unit Power Supply
    Power Module Input Voltage:
    USA: 120Vac + 10%.
    CE marked module 100 - 240 Vac, 43 - 63 Hz.
    Frequency Range:
    47 - 63 Hz.
    Power:
    36 VA maximum.
    Output Voltage:
    23 Vdc nominal at 1 ampere.
    CE marked module: 24 Vdc at 1.4 ampere
    Output Current:
    1 ampere dc.
    Dimensions (H x W x D):
    Power Tee: 1.33 x 3.15 x 4.08 in. (34 x 80 x 100 mm).
    USA Power Module (with mounting bracket) 2.74 x 2.86 x 6.30 in. (69.5 x 72.6 160 mm).
    CE Marked Power Module (with mounting bracket): 3.00 x 3.13 x 6.30 in. (76.4 x 79.4 x 160 mm).
    Weight:
    Power Tee: 8.0 oz (0.22 kg).
    USA Power Module (with mounting bracket): 42 oz (1. 18 kg).
    CE Marked Power Module (with mounting bracket): 44 oz (1.25 kg).
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    u got a pic? i could tell u exactly what the set-up was for. heck i prolly have anything u might need to complete if its missing. have to know the size of the couplings. is this off civillian?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have no idea if its civvy or what, i dont know jack about cb/antenna stuff, at all
    its got antenna coaxial cables though, smaller diameter fittings, not the huge ones you see sometimes
    other than that i dunno
    i have no digicam currently
    thanks
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if its the smaller stuf its prolly VHF or UHF not "CB" could be many things. not that that helps out to much. was there an antenna? u just have to measure that and could tell u from that too
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it doesnt have TV type cabvle ends, it has uhm CB antenna cable type ends but not real big
    hmm
