Anti-freeze Is Leaking In The Cab
Discussion in 'The Garage' started by K-5krazy, Sep 17, 2006.
  1. K-5krazy
    K-5krazy Registered Member
    Nov 15, 2005
    31
    Hattiesburg, MS.
    In my 87 K5 Anti-Freeze is leaking inside of my cab right under the glove box. The truck started to leak when I turned on the heater. Then it would leak when I turned on my vents. Now its gotten to the point where it leaks all time and it gets worse the harder I press on the gas, plus my thruck is starting to over heat if I dont add water. I think its leaking from some part of the heater or has somthing to do with the heating systemin the truck. What can I do to fix this problem and what exactley might be the cause this leaking problem.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
  3. K-5krazy
    Nov 15, 2005
    31
    Hattiesburg, MS.
    Oh sweet thats not to bad thanks for your help
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    The part is pretty cheap, which is always a good thing.
  5. Can Can
    15,552
    136
    No problem, brother. That's what CK5 is all about!!! :thumb:
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    hold on a sec...it might not be...this happened to me to... Make sure to check the hoses. one is 3/4" and one is 5/8". sometime people will replace them and not realize theres a differance(run 3/4" for both) and the hose wont seal and it leaks right into the cab. ask me how i know:rolleyes:
  7. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    my heater core cracked also a while back, same analysis as you gave, Except during dead winter and i never checked my passenger floor, always wondering why my truck was getting steamy inside.... derr de derr. Honestly, replacing the heater core was a b****. Could have been the 35* temps outside working at night in the dark, but i do remember hammering, cursing, and breaking bolts purposely just to get the thing off the firewall. Good luck man, and if your not afraid to take your pass. fender off, do it, it will make things easier.
  8. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    That write-up helped me alot on my first heater core replacement.. now ive done 2 more without a problem!
