Anti-lock brake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tori89k5, Feb 12, 2002.
  1. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    My '90 model has rear anti-locks, but have noticed that they really dont "anti-lock" wondering if this is to be expected with oversize tires, or if my system just isnt working properly.
    Anyone have any experience with their system ?
    1990 K5 4" lift, 33" MTR's, 14FF w/ Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides !
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    System isn't working. ABS goes into regular brake mode when there is a fault with the system.
    Bubba Ray Boudreaux,
    Official Colorado K5.com Fantasy Football Choke Artist!<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  4. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    An antilock problem will generally also illuminate the "BRAKE" instrument cluster lamp.
    Like said before, the system reverts to "normal" mode if a fault is detected. The ABS computer is under the hood, outboard of the master cylinder. I'm not sure if it's linked to the main ECM or not, but I would see if it registered a code.
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/abshort>U.S.S. Nimitz II</a>
  5. tori89k5
    Apr 12, 2001
    946
    No illuminated brake warning lights and no codes in system.... Guess i will try to have it diagnosed. I'll keep ya'll posted
  6. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    I have the same problem with my 90 jimmy. Have you found anything out yet?
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Hey Tori, I see you are locked. That will raise hell with ABS. I had problems with mine. Read up on it and discovered ABS diffs rely on something called an exciter ring?? If this is missing it seems to cause problems. I'm not sure how. I just discoed the ABS and problem solved. My thinking is ABS doesn't help on the trail and never used it on the street before now either.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
    <font color=red>Because I, Am, Canadian!!!</font color=red>
  8. tori89k5
    Apr 12, 2001
    946
    Yes,...... Had a tech. at work put the Snap-On scan tool on it and it says the ABS sensor is "open" I am ordering it from GM this week. Part # 15547452 think its like $80 or so. I will let you know if that fixes it. Later.... TORI
  9. tori89k5
    Apr 12, 2001
    946
    Yo Shawnboy....... thanks for the tip,..... however.... our rigs dont use the type of "exciter ring" you speak of. Those would normally be found in the differential,..... like on the ring gear. Our trucks us one that is in the transfer case.... it only senses when the driveshaft locks up....
