anti rattle thing that go inbetween gas tank and straps???
Discussion in 'The Garage' started by down4thakrown, Jun 13, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    cant remeber what there called but the pieces of cloth like material (atleast what it feels like) that goes between the gas tank and straps is almost all gone and i was wondering if any body is using a substitute to replace that or should i go buy some outta lmc or a junk yard??
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    If its just to keep it from rattleing, anythign would work that, like rubber or whatever.
    I'd use some garage door weather stripping......
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I used roofing felt (aka: tar paper)
  4. K10bolts
    K10bolts Registered Member
    Feb 8, 2005
    35
    Big Rapids, Michigan
    an old inner- tube
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    When I did mine I had some old roofing felt and for all intents and purposes the anti rattle straps looked and felt just like the roofing felt.
  6. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I've used peices of broken straps before.
  7. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I have used old truck inner tubes, the thicker, the better.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The home stores sell a roofing product with adhesive on one side. Makes a good poor man's Dynamat too.
  9. dyeager535
    26,975
    Roofing felt here. Almost (if not) identical to the roofing felt I had in my shed. Cut in strips, apply.
    Probably not a concern in your area, but I painted my tank where those strips are, since they tend to retain moisture against the metal.
  10. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i thought those strips were something special and bought them from LMC.
    i felt like a chump when i open the box and seen several pieces of roofing felt.
  11. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    home depot to the rescue...
    We have used the "closed cell" pipe insulation you can get at home centers and hardware stores,that is slit lengthwise to put over water pipes(makes great roll bar padding too!)...I've used tarpaper as well...or duct tape..my dad used to get special 3M brand tape from the gas company that was used to wrap pipes to prevent corrosion--I've used that on the tank to prevent rust where the straps touch.. we've got old gas pipes we used for garden stakes for many years,and that tape is still like new,no rust on the pipes.. :crazy:
  12. BlazerFarm
    BlazerFarm Texagonian Premium Member
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    I couldn't find them either when I replaced my straps, so I asked the GM dealer parts department. He said that they recommend 3M Camper Tape. That's the foam tape that goes on the pickup bedsides that the camper sits on. So I went to NAPA and bought a roll. No squeaks.
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I use cork gasket material...anything else holds moisture...rusting out the tank.
    But that's here in the rustbelt. :crazy:
  14. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    ditto
  15. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    tubed...
    My friend who has a commercial shop does lots of tanks and fuel pumps--he often uses bicycle inner tubes over the straps..he also used one to test leaky radiators before he bought a pump up type pressure tester--he simply cut one in half and clamped both ends on the radiator,filled it,and inflated it to 15-20 psi!..worked slick!.. :crazy:
  16. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Now thats a good idea! :D
