ANTI SWAY bars on first gen..front end?
Discussion in 'The Garage' started by TONYP, Aug 22, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    anyone done it and do you have picks and parts needed... /forums/images/graemlins/ears.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    these are some pics from Steve Chin's web page:
    He just used a 73-up chevy 4x4 sway-bar and spring plates, and made the bar mounts that go onto the front cross member.
    I have been thinking of doing the same thing but having the sway bar go behind the axle (not in front of it like on a 73-up) so that cross over steering would fit when I eventually get it.
    Check out the rest of Steve's site at
    http://www.geocities.com/MotorCity/Downs/1963/BlazerPix.html
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I was about to mention Steve Chin's install and pictures but Triaged beat me to it. /forums/images/graemlins/thumb.gif
    I have kept those pics saved for quite some time in case I install a sway bar in the front of my Burb. /forums/images/graemlins/thumb.gif
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I did it.
    I used hmmmmmm....here it is
    http://www.addco.net/
    Was about 8+yrs ago I put it on...I'll have to look for some pics for ya...
    I also have quick disconnects from Persson Off Road, Toyota site (my book mark no workiy??)
  5. I am in the process of putting a (god forbid) YJ swaybar on the front of my 72 blazer. I am using it because the ends are the proper width, it is wide enough to bolt directly to the frame rails and the trailing parts of it are short enough to keep it behind my pitman arm (I have crossover steering) I will be using bushings and straps from a 78 (god forbid) Bronco swaybar to mount it to the frame to keep the bar well below my harmonic ballancer. Pics to come later. /forums/images/graemlins/grin.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    If you succeed, be sure to post pics......! /forums/images/graemlins/thumb.gif
    I have NEVER seen a photo of a swaybar setup on a K5 with crossover steering. I would sure like to though....
  7. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    there is a book out on the history of the K5 till around 1981....anyways they reprinted an article from a early 70's rag doing just what you want to do...
    DW
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    Burt,
    checked out addco and looks like they have what I'm after...I think you have the 7-leaf pac on the front, what is the lbs and how did the ride change...was it a big change? /forums/images/graemlins/thumb.gif
  9. Burt4x4
    6,854
    I think I have 5 leaf Rancho 4" up front.
    My rig would start to rock back and forth on uneven pavement jammin down the road. It got so bad once all I could do is hold the stearing wheel and pray I wasn't gonna smak into that big rig comming the opposite way. After that scare I put on the sway bar and now my rig just bounces up and down instead of side to side...WAY better.
    I would get some kind of disconnects cuz wheeling with the bar attached will bend the lower mounts that bolt to the springpack.
    Good Luck /forums/images/graemlins/thumb.gif
