Anti wrap spring pads?????/
Discussion in 'The Garage' started by ben427, Jun 6, 2004.
  1. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Havent found anything on search, but i was wondering if anyone has made spring pads to control axle wrap. Im getting ready to swap an built 454 and nine inch rear in my 1988 2wd pickup. Seeing as how i need to make new perches anyways, what if i were to extend the front of the pads out 6-8 inches infront of the axle, kinda like slapper bars, would it make any difference???
  2. ben427
    Mar 10, 2002
    1,123
    To hell with it, ill try it and let Y'all know if it helps /forums/images/graemlins/thumb.gif
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    I would suggest building a traction bar, simple mod and will help quite a bit.
  4. ben427
    Mar 10, 2002
    1,123
    Ill probably end up with ladder bars if its to bad anyways /forums/images/graemlins/thumb.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    what's the difference between ladder bars and anti-wrap bars? /forums/images/graemlins/confused.gif
  6. ben427
    Mar 10, 2002
    1,123
    well not to much. ladder bars are basically two suspension links that keep the axle from rotating. dont allow as much articulation as any off the offroad anti wrap bars, but work good for street vehicles.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Jeep guys build 6-7" long perches to try to keep their springs from fatiguing after the go SOA. I've seen shocks that mount between the front spring hanger and the main leaf half way between the spring plate and the rear spring hanger on some older Dodge pickups. I suspect it was there to keep axle wrap at bay.
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I'm not sure if the extended perch would conact the overload, as they usually get thinner towrd the end. The overload doesn't wrap anyway, the rest of the pack does. I'm not sure it would help very much. /forums/images/graemlins/dunno.gif
