Antifreeze leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frogg89, Jan 26, 2004.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    I noticed that after quite a while that my antifreeze level is dropping so I put a pressure tester on it and it slowly but surely says I have a leak. I looked everywhere, even snugged up a few places and I couldnt find it. Then, I saw some antifreeze on the bottom of my starter so I looked up top and the hose going into the back of my engine isnt leaking a drop!!! Has anyone else had this problem before? I cant find this damn leak!!!! /forums/images/graemlins/k5.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Freeze plug possibly? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Is it dripping out of the exhaust above the starter? If it is could be head gasket..if you're lucky
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Only an Air Force SSgt would think he'd be lucky if it was a head gasket leak!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I dont think its coming out of the exhaust. The head gaskets were replaced about 2 years ago!! The freeze plug could be though!! Its so slight that it doesnt even show up under the truck!! Not a drop on the ground.
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What's a few bolts here and there /forums/images/graemlins/1zhelp.gif
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have the exact same leak on my 84. It's coming from one of the freeze plugs on the back of the block in front of the tranny........ /forums/images/graemlins/tongue.gif
    There's a chance your leak could be coming from the frost plug right behind the starter. You'll have to drop the starter and check it out- for your sake I hope that's what's leaking. To get to the frost plugs on the back of the block you have to drop the tranny.
  8. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Check the easy stuff first, like all the heater hose connections.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  9. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Hey, I just wanted to unfortunately let you guys know that it is the head gasket!!! It must have gotten a little worse and I was able to see where the leak was coming from!!!
