Antifreeze problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biggedraws, Feb 11, 2002.
  1. Biggedraws
    Biggedraws Registered Member
    Apr 13, 2001
    57
    Gilbert, arizona
    I have a problem..... For some reason i have antifreeze leaking into the inside of my truck down by the floor board on the passenger side.... Any suggestions?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    your heater core is leaking. you will probably need to replace it, as I don't think you can fix it. There is a right up on how to replace it in the Technical section of this website.
    My Chevy isn't broken, its just out of gas.
  3. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Sounds like new heater core time, but be sure to check the heater hoses where they enter the firewall for leaks first.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Look up Grim's article on heater core replacement. It is a lot better than anything you will find in any of the manuals. It is a PITA job, but after you have it completed you will be glad you didn't pay someone to do it.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60, 4.56, Corp 14B Detriot, 16x10 AE 589's, 37x12.5 SSR
  5. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    or if you dont care if the heat works
    cut the heater hose and install a shutoff valve
    did that in a vette i had once, cause in the summer even with the heat off it would get way hot inside, and then after the shutoff valve install it was a little cooler inside
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    hehehe... my friend and i were driving in his 88 bimmer one day and a tiny bit of smoke came out behind the steering wheel (its usually never cold here but it was that day and he was using his heater first time in a lkong time) and then all the suden we heard some *psss* and smoke starter pouring out from the driver side floor. And we were like "crap!!" so he pulls over and theres all this antifreeze on the floor andit was his heater core that busted... cost him a good chunk of $$ but of course its an import and the guy obviously riped him off
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 6"susp, 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
  7. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    Thnx Alot.
