Antilock Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Feb 24, 2001.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Has anybody converted their Blazer from antilock brakes (rear) to regular brakes? Here's my problem, in 2wd the back brakes won't work, but in 4wd they do. Got scared backing down a hill and the front locked up and the rears were still spinning. This is on a 91 Silverado. I checked the prices and for the control module and the hydraulic unit it's about $200.
  2. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    The RAWL is not working in 4WD (thats the way is shoukd be) so thats why you can lock them when you are in 4WD.
    In 2WD the RAWL is working now you can`t lock the brakes until you are at still stand. That`s the way Rear Anti Wheel Lock is supposed to work.
    hope this helps you a bid.
    greetinng from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "32, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Everything Hill said and ... your front brakes have a heavier bias (more weight up front + more weight transfer). So when you go backwards (especially down a hill) the fronts lock up.
    The whole idea behind anti-lock is NOT to lock-up a wheel. This is fine on pavement but on dirt this can result in abnormally long stops. On dirt a locked wheel will actually push a small mound of dirt in front of the wheel, slow the vehicle down. Anti-Lock prevents that and the wheel continues to roll over the top of the loose surface.
    Understand how it works, what it's supposed to do. Locked, skidding tires do not stop quicker on pavement. If you do a LOT of dirt road driving (at speed) maybe you need to wire up a disconnect to the RWAL until you hit pavement.
  4. pr1aw
    Sep 17, 2000
    144
    San Diego CA
    The problem was, when I was backing down a hill with pavement, I skidded with the front for about 20 feet and the rears did absolutely nothing, no inkling of even trying to stop. It finally leveled out some and the fronts did the work of stopping it.
  5. littonk5
    littonk5 Registered Member
    Dec 6, 2000
    14
    Tucson, AZ
    If you are truely having problems with the anti-lock brakes, I suggest you contact a dealer and see if there is a recall/extended warrentee on them..my jeep(91) still had an exted waurenttee in place at 140,000 miles because of the safety issue.
    good luck
  6. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    On my '91 Caprice if the sensor was disconnected and the speed was up over about 5 mph the anti-lock computer shut down and stayed that way until the car was re-started. Try just un-hooking a sensor, any will do.
