Any advice?.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by shaun, Sep 18, 2003.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I am going to pull my 327/sm465/dana 20 this weekend and was curious if any one knew the best way. I have pulled all these off my 85 but it was an auto and I dont know if there is a difference with a manual. Also should I pull the transfer case and tranny as one piece or pull them seperate?
    /forums/images/graemlins/eek.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I'd pull em seperately. Less chance of the whole shebang, falling on you, or crushing a hand, etc. It's a little messier, [oil and goo] but it would be easier, IMO. /forums/images/graemlins/grin.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My advice is to unbolt the tranny tunel and drop the hole thing out from the top with a chery picker. When I rebuilt my TH350 I dropped it with a tranmission jack (along with a floor jack under the 205) It was hard getting under there to unbolt stuff and hard to balance.
    When I put it back in I bought a chery picker from Kragen and lifted it up from the top. The hoist fit right in the door and left the hole under side of the truck free to work under. My th350/np205 combo balanced right where the adapter bolted to the trans with a chain around it. To tilt it into place I just had to put a small ammount of pressure on it. If only GM kept the removable dog house...
