Any alternatives to the streetwires power distribution block?
Discussion in 'Audio' started by afroman006, Oct 12, 2003.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Since I'm going to be running 3 amps I need something like this but I can't really justify the price. Anyone know of any others or how to make your own? Here's the one I'm talking about
    block
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The thing that makes that junction block so big and $$$ is that it also has the grounds built in. You don't need that (unless you are going for the Bling Bling look). I also don't see the need for a fused dist. block. There will be a fuse at the battery connection to protect you if any of the hot wire shorts to ground. The amps will all have fuses as well...do you really need 3 fuses in series? When you get down to that point the price will come down alot!
  3. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    Most of what you are paying for there is the name and the looks. Take a look at the link below for some other much cheaper options. Also, roam around the rest of the site for good prices on wires, fuse panels, caps, and the rest of the stuff you'll need to wire up your system.
    Parts Express distribution blocks
  4. afroman006
    Aug 21, 2002
    2,876
    I'll be pushin about 700 watts total RMS so I think I need 1/0 gauge wire goin into the block. Will that one on the top accept cable that heavy? Thx for the site.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I think you are WAY oversizing the power wire for your application.....
    700 watts RMS is substantial, but 1/0 is massive!!! That's what I'm using for a 1600 watt system....and it's probably overkill for that.
    There are sites where you can get the correct wire sizing based on current demand and wire length. I'd start with a Google search on "AWG sizing" or "AWG Chart".... that should help you figure out what's needed.
    The distribution block is just the beginning of the rediculous costs when you do the real heavy wire gauge stuff....I think the 1-0 AWG stuff I bought was about $7/ft!!!! /forums/images/graemlins/eek.gif Yet another reason to make SURE you really need it.......
    /forums/images/graemlins/thumb.gif
  6. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    The distribution block is just the beginning of the rediculous costs when you do the real heavy wire gauge stuff....I think the 1-0 AWG stuff I bought was about $7/ft!!!! Yet another reason to make SURE you really need it.......
    That's why if you aren't going for "bling bling" you go to a welding supply store where you can get 1/0 awg for about $1-2 a foot.
  7. afroman006
    Aug 21, 2002
    2,876
    Lol well in that case do y'all think 4 gauge will work to the block then 8 gauge to each amp? I am not into bling bling so i dont need the translucent coated wire crap. Also, are all those fancy speaker wires worth the extra cost or will the speaker wire from radio chack work and sound just as well? Thx
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you just want a power distribution block really cheap, look under the hood of an '88 to '00 or so GM pickup (or '92 to '00 Suburban or Tahoe). On the firewall, above the a/c box, is a black plastic shroud that covers the fuel pump relay and a pretty nice 5-stud power distribution block. It isn't anything fancy, but it can handle a lot of current. I paid $1 for the one I picked up. /forums/images/graemlins/thumb.gif
  9. afroman006
    Aug 21, 2002
    2,876
    I just remembered the CUCV's I have all have 2 in the engine compartment. Problem solved. Free parts are cool.
