Any bets on my Front 10B's lifespan?
Discussion in 'The Garage' started by MTMike, Feb 6, 2006.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    MNorby Lincoln-locked (Actually Miller Locked if you wanna get technical) my front 10B this weekend for me.
    10:1CR 383 Stroker, 38.5x14.5"Swampers, and now welded.
    So far, it's survived a year of this being open with me and 2 years open with the previous owner as mud racer.
    Any bets? :D
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Do you plan on turning?? May require a football field worth of room to get 'er turned. Stock internals? She gonna blow up real good!!!
  3. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    If you drive anything like I do, first trip, first time you get on it decently. Looks like you have xover so steering shouldnt be too bad.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I think it'll be fine until the snow melts. After that and you can actually get some real traction...not very long.
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm not concerned about turning because I can just unlock a hub, and the only time I'm ever on the throttle is in the snow. I know the things a toothpick and treat it as such, but I just needed more traction in the snow.
    I don't do any extreme rock crawling or mud racing.. just mild to moderate trails (3-4) in the summer and snowbogging in the winter.
    Mike
  6. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    my only request is that when it does blow show us some pics :) and good luck with it lastin you the winter
  7. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Well if you welded it properly the first thing to break should be the axle's so a 15 min swap and your on your way. Just out of curiososity did you phase the u-joints before you welded it? If so let me know about your steering feel when turning. I think if you run 1 hub unlocked and dont get on it to hard it might last a while, just carry some extra shafts with spicer 760-x u-joints.
