Any Certain Year for 205 T-Case
Discussion in 'The Garage' started by crazyhole812, Apr 29, 2006.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i'm going to call a local 4x4 yard today. i was wondering if there was a certain year of 205 i should look for. i just figure before i buy new driveshafts i should get a 205 and put in the low gears, and get rid of my 208. seem smart? or should i just keep the 208? i am planning on running 42's and was trying to avoid running 5.38 gears.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I can tell you what year to avoid, any 1980 model. Those years had the slip yoke like your 208. Some 80s model 1 tons had them too, so keep an eye out for them. Not sure if you can take a 205 with adaptor and bolt it to your trans, they had a bunch of different configurations for tailshaft lengths. I'm sorta going thru this with a 400/205...
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I wouldn't just rule out "any" year model of 205 especially if it has the slip yoke. The slip yoke housing can be easily removed and replaced with a fixed yoke after one has been found. A few vendors on this site sell some for around $100 or so.
    There is no specific year of any 205 to avoid. The thing I would watch for are the adaptors. I'm not fond of the earlier adaptors that were mated to the 350 turbo trannys as those used ball bearings inside them. The newer 205/350 adaptors have seals inside them instead. Read/heard somewhere that the bearing type adaptors are weaker than the seal type. Don't know if its something to do with the added stress from the torque of the rotating shafts, coupler sleeve and the material of what the adaptor is made from that causes them to crack.
    Other things to watch out for on the older 205's are the front output shafts having 10 splines instead of 30 like newer ones do. If you wanted to run larger u-joint yokes, the 10 spline will allow that whereas the 30 spline won't. A Ford 205 front output shaft can be swapped in as it has 32 splines and therefore you can install joints up to 1350 series.
  4. crazyhole812
    Jul 6, 2005
    228
    missouri
    thanks guys. oh and i do have the 465 trans. so i would want the 10 spline or a 32 spline off a Furd?
  5. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    your trans will need the 10 spline for the coupler
    here is a pic of the adapter you need also make sure you have the right seals in but wait if you have a 208 don't you have a lower gear than a 205 or is that a 241? hmm cant remember
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Is your 465 a 10 spline output shaft? If so, then you need the common and easy to find 10 spline 205.
    Whether you want the 10 or 32 spline front output shaft will determine what you want to do with your rig. If you are just doing a daily driver/mild offroader, leave the front output shaft alone. If you are building an all out offroader, find the Ford shaft and install that.
    If your 465 output shaft has 32 splines, you need to find any 205 out of a K30 from '85 up to '91.
    The 10 spline 465's will be easier to find the 205's as they go way back down to the 60's.
  7. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    quote" i am planning on running 42's and was trying to avoid running 5.38 gears."
    The 205 will not help you with this. It only has a 2 to 1 low range, while the 208 has 2.61 to 1 low range. I believe someone has started making 3 to 1 gears for the 205, but it comes with a new case and the price was over $1000 I think. The 205 just excels in strenght, but the 208 does have better gearing..
    Good luck
  8. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    a 208 is what i want to put in place of my 203, once i find one and a th350 adapter and crossmember for one for my 77
    we need to know what year 465 tranny/truck you have
    spline count even better
    they changed the spline count on the 465 by 83
    so,
    good lcuk
  9. crazyhole812
    Jul 6, 2005
    228
    missouri
    thanks guys. those low gears for the 205 is what i was thinking of but i'd rather not pay over 1000 bucks for it. i guess i'll stick with the 208. is the slip yoke a problem? i thought i read they could crack or something. my truck is an 87 3/4 ton. it will be offroad only. i have a 383 stroker. i will be running 42's
  10. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    the same company that makes the lomax 205 the 3 to 1 case previously mentioned i am almost positive has a slip yoke elminator kit you can buy to remover that and have a fixed yoke
  11. crazyhole812
    Jul 6, 2005
    228
    missouri
    is that thing legit? once again i only read this, but i thought some people thought it was a crappy way of having a fixed yoke?
  12. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    find a 241. it will bolt right in if from behind the same tranny and you can buy a sye kit. Otherwise use dodge parts to sye your 208
  13. crazyhole812
    Jul 6, 2005
    228
    missouri
    what dodge parts or what year? just need the rear output cap? thanks man. by the way norby , got any pics you could e mail me of your cage?
  14. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    if i remember right there is some machineing needed to be done too. Do a search for SYE 208
  15. crazyhole812
    Jul 6, 2005
    228
    missouri
  16. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    Chevy never used a fixed yoke 208... Dodge and Ford did. Not sure why Ford stuff couldn't be used, but apparently it won't work. Not sure what year Dodge stuff either.. but if you look under a Dodge and see a 208 with a fixed rear yoke, I think you're fine. Parts oughta work for ya.
    front outputs are always fixed... so yeah, rear output stuff is all you have to work about.
    j
  17. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    If your NP208 was hooked to the SM465, it will be a 32 spline output shaft.
    The only wrecking yard combination that will work for you is to find a NP205 from 1985 and later, mated to a SM465. You will also need the transmission adaptor.
    We offer complete rebuilt 3:1 LoMAX NP205 transfer cases, and we will have somthing to replace your NP208 for the added strength and low range.
    -Kyle
    NWF.
  18. 85gmcOD
    85gmcOD Registered Member
    Jan 24, 2006
    62
    greentown, pa
    hijack
    what do u mean.... something to replace ur 208.... u just mean puttin the 205 in with the 3 to 1 reduction.. and is there anyway to make that 205... and how much . i have a np 208 and was just about to do shafts and thought about a t case becaus ei dont wanna go out and spend all this money on a shaft that wont work at all if i change the t case.. i eventually wanna get a big block and 44's so all mods are pointed to that direction. thanks
