Any Cheap & Easy ways to relocate Rear Shocks Inboard ??
Discussion in 'The Garage' started by 88Silverado, Feb 13, 2004.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Im looking for ideas on relocating my rear shocks inboard.
    I know 55Willys use to make a mounting setup and a new Mo-Offroad setup is out of my price range with shipping (although it does look pretty easy)
    Anyone else make their own?? Ideas??
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You may want to have a chat with Stephen Watson about this before you go too far, especially if this rig gets driven on the street. When you move the shocks inboard they lose most of their ability to help stabilize the rig in corners because they are then too far away from the ends of the axle housing, which is where most of the movement occurs at that time. /forums/images/graemlins/frown.gif
    I think that Toby (moneypit) also noticed a huge difference in handling when the gang at ORD moved his shocks back towards the ends of the rear housing.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That might be a viable deal, but why is it that you look at all ford and dodge trucks and all there shocks are inboard stock from the factory?
  4. 88Silverado
    Mar 13, 2003
    2,664
    Mine is a daily driver. My concern is after I did the 4" lift, I got 8403 shocks for all corners. There isnt much room for upward travel (especially with the rubber stop) and am afraid of breaking the mount. Maybe I need to go to a shorter shock or cut the stop off.
    Im sure if the shocks were mounted way inboard there would be some problems. Just like I dont think the stock setup can be layed back any farther. Looking for some ideas,
    Thanks /forums/images/graemlins/thumb.gif
  5. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Yup ,coppied it from someone on this site. /forums/images/graemlins/thumb.gif
    Cost............nuthen
    Truck still rides and corners fine and I dont bottom the shocks out (i think there rs5012's)
  6. 88Silverado
    Mar 13, 2003
    2,664
    Interesting....
    What are the lower mounts?? Are they just welded on?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check out the pics that rock.monkey posted. As the shocks get on a steeper angle, they will move less for a given amount of axle motion, reducing their ability to do their job. The more vertical they are then the better they will work.
    As for the Ford and Dodge question above... Look closely next time. See that big sway bar that they come from the factory with? /forums/images/graemlins/wink.gif
  8. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I pretty much copied the pics that Rock Monkey posted. Only thing was I put the mounts on the axle behind the tubes, so they wouldn't get crushed. Madeb the top mount out of 1.5 .120 tubing, then mounted the studs in the tubing. The mount has brackets that bolt to where the bumpstop rivets were.
    As far as the shock angle, If your building your truck to carve corners then don't do this mod. But if you do like most everyone else, your not going to be road racing, and believe it or not I can hardly tell the loss I had in dampening. I almost think it rides better now. /forums/images/graemlins/thinking.gif
    If you want the longer shocks, and don't want to cut into the floor for towers, do it. /forums/images/graemlins/waytogo.gif
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    email me since I'm blue, but I'm in the process of moving to Boise,ID so I'm going through all my stuff and selling what I have laying around, I can probably round you up one. /forums/images/graemlins/thumb.gif
    -Jeremy
  10. rock.monkey
    Oct 28, 2000
    296
    Bottom mounts are 3" channel. I drilled a hole in them to bolt the stock mount into them then welded them to the tubes.
    The top mount is just bolted to the bump-stop brackets.
    As for handling, it's better now.
    If you need larger pics, let me know.
  11. 88Silverado
    Mar 13, 2003
    2,664
    Larger pics would be great!
  12. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Here's my set-up. Total cost $12. Does it handle differently? yes. Is it worth the extra flex? Hell, yeah! /forums/images/graemlins/peace.gif
    *Note: I added zero-rates since this pic and cured bottom-out. (They were part of plan all along)
  13. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    What did you use for the cross member at the top? Any more pics of how they are mounted?
    Bill
  14. DougK20
    Feb 18, 2003
    384
    Boise, ID
    I made the crossmember from 2" angle iron. Cut, drilled, and painted. Then I drilled through the upper frame to mount it. I found some small brackets at a local 4x4 shop and welded them on the tube (thx muddinmike!).
  15. rock.monkey
    Oct 28, 2000
    296
    I put some larger pics. up in my members section the names on the larger pics. start with rear. /forums/images/graemlins/thinking.gif /forums/images/graemlins/peace.gif
  16. 88Silverado
    Mar 13, 2003
    2,664
    Wow...that looks simple enough. Have any closeup's of the crossmember frame mount?
    Also..is that a 14SF rear?
  17. DougK20
    Feb 18, 2003
    384
    Boise, ID
    Sorry, no close-up shots. Just scoot your chair really close to the monitor! /forums/images/graemlins/doah.gif Yes, it was really easy and I enjoyed building it. Thanks for asking!
    BTW, it is a 14bsf w/Detroit
  18. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    btw, i DD my truck with the shocks set like this /\ everyday. It handles fine. I also have no sway bar or any kind of stabilizer on the D60 frontend. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif
