Any close up pics of ORD Add a leafs??
Discussion in 'The Garage' started by wakedog, Sep 25, 2002.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Does anyone have close up pics of the ORD add a leafs installed with the axle moved forward or pic?? I just dont get how exactly they work. Now say i want to move the axle 1.5 in forward, Does the orginal spring center pin go throught the middle whole on the add aleaf and the you put a second center pin(so to speak) through the hole on the add a leaf that is forward 1.5 ins forward?? So the second center pin will locate the axle and go in to the hole on the spring pad?? Then you have to drill a hole in the u bolt plate for the main center spring because of the offset caused be the axle be 1.5 in forward?? Sorry for the confusing post put im not quite sure if thats how they work or if they work a different way. Thanks
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Yep that's how they work. /forums/images/icons/grin.gif
