any comments about attaching seats to the cage (with pics)?
Discussion in 'The Garage' started by ugly, Sep 7, 2004.
  1. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    I am installing new/used seats into the beast... I can't decide if I should attach the seat mounts to the cage or skip it?
    I know this has been discussed many times...it is better to attach them to the cage... I don't know if this applies in this case. Feed back please.
    Ugly is getting uglier! I'm no fabrication pro- no tube bender. /forums/images/graemlins/screwy.gif /forums/images/graemlins/grind.gif
    Seat frame attached to the roll cage behind the seats and mounting plates attached to stock seat holes.
    Without being attached to the front roll cage?
    Or, attached to the front cage?
    PS- copeing without a jig/drill press is Slooooow! (grinder)
  2. CK5
    May 19, 1999
    21,627
    704
    CO
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea you really need to attach the seats to the cage, if you roll and the cage or body shifts you could get really hurt, I would take off the mount that goes to the stock bolt holes and tie it into the bottom cage mount. /forums/images/graemlins/thumb.gif
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    not sure if you have seen this but here you go, this might help you out some,
    ck5
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    crap you beat me to it /forums/images/graemlins/doah.gif
  6. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    any problem leaving it attached to the stock bolt holes and adding the brace to the front cage... may not be perfect, but is it safe?
    I like your setup but my cage does not hit the floor where yours does, and I don't like a bar running higher off the floor than where yours is. That is part of the reason why I designed it this way.
    This is coloradok5's rig.
  7. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    bounce
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That is almost exactly how mine is set up. Makes hoseing off the floor easier. /forums/images/graemlins/grin.gif
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    im attaching mine to my cage, because with all the rust, I am even skeptical of standing on it /forums/images/graemlins/doah.gif
