Any difference between 1/2 and 3/4 ton 10 bolt axle shafts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Aug 30, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Are the 28 spline 3/4 ton and 1/2 ton front 10 bolt axle shafts interchangable? If not, anyone know the differences?
    Thanks,
    Thomas.
    -- '84 K5 Blazer --
    <a target="_blank" href=http://stoopalini.off-road.ws/blazer>My Blazer Site</a>
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    As far as I know, as long as they are both 28 splines from 10 bolts they are interchangeable irregardless whether its 1/2 or 3/4. I think the only difference is the rotors (maybe calipers too depending on size). Side note, they cannot be interchanged with the D44 which has 30 and even a different length and taper than the 10 bolt 30 spline axles (which are not as common).
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The 3/4 shafts may be longer but Im just guessing. I dont really know!
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Well since its a guessing game, I'll say they are the same !
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    They are the same.
    No guessing. The only differnce might be in the outers and the placement of the snap ring grooves. Watson at ORD can give you a little more info on those
    Kyle
    89K5
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Same thing.
    Calipers are all the same too.
    Tim
