any differences btw 1/2 and 1 ton master cylinders
Discussion in 'The Garage' started by TorkDSR, Sep 14, 2004.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    performance wise, is there any difference between the two, both assuming vaccuum assist. is there any more fluid moved, or a higher pressure?
    thanks.
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Good question. my 1 ton has a big master cylinder but it is hydro boost, so sorry I cant help.
  3. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    You wont find a 1 ton with vac assist, you'll have to drop back to 3/4 ton.
    I'm not real familiar with the later plastic resevoir stuff but when dealing with the earlier iron resevoir type m/c's a 3/4 ton version typically has a larger resevoir.
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    1 ton has a larger bore.
  5. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    thanks
    and, im not sure if the 1 ton ever came with a vaccuum booster, but i have listings at work so, i ordered it. $18
    and upon further research, the 3/4 ton and 1 ton vacuum booster master cylinders are the same number....
    so i guess now i have another question, is the 3/4 ton vaccuum assist also a larger bore?
    and does a hydroboost master cylinder bolt up to a vaccuum booster....?
    thanks again
