Any electrical gremlin guru's in the house, Ghost in the tail light
Discussion in 'The Garage' started by chevyfumes, Jul 10, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Any electrical gremlin guru\'s in the house, Ghost in the tail light
    My wife has a 98 Cyrapstler Cerious and the right brake light dosent work it's not the fuse or the bulb, heres the wierd part I unplugged the entire brake, back up and blinker assembly and plug it into the drivers side and the brake light works... OK then I figure it's the wiring , so to make sure I take the drivers side assembly and plug it into the right side and the brake light works...WTF Basically I have 2 light bulbs and 2 recepticles and one bulb works in both recepticles and one bulb only works in one side, the wrong side. What sucks is there not interchangeable, but I told the wife I could duck tape them on /forums/images/icons/laugh.gif .... /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Re: Any electrical gremlin guru\'s in the house, Ghost in the tail light
    Check for broken fillaments (lil curly wire inside the bulb)
    I've seen them broken free and go out, then whan you go to check, the lil buggers "re-weld" them-selves in place and appear to be O.K. (unless you tape the bulb and break the weld).
    Also check the base of the bulb for corrosion or some other poor-connection.
    Check the conectors for proper terminal tension. (check to see if the terminal is squashed)
