any experiance with POR-15?
Discussion in 'The Garage' started by dodgetruck91, Jan 18, 2004.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    just wondering if anyone has had any experiance with POR-15? if so how do u like it? /forums/images/graemlins/k5.gif
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I did the floorboard from the pedals to where it goes up in the back 2 years ago and it seems to be holding up. I did the part of the bed by the tailgate and rockers 3 years ago no new rust.
    I also used there engine paint last year and it took a week to dry but its as shiny as the day it was painted.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Do a search, this has been brought up numerous times...usually people like it but it's expensive... /forums/images/graemlins/deal.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    When I did my narrowing job I found some pretty impressive rust. I plan on using it as it seems to overall get good reviews.
  5. b55baron
    b55baron Registered Member
    Jun 3, 2003
    39
    Marietta, Ga
    I've sprayed it with good results. I buy the 4 oz. cans because once a can is opened, it has a fairly short shelf life.
  6. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Did my frame and axels with it with great results /forums/images/graemlins/thumb.gif
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    My shelf life has been pretty good- I got the larger quart sized sucker, and just sealed it back up and put it in the fridge. Been there for at least a year, just used it on some rusty brackets and tools, still works good. Taking a piss long time to dry in freezing weather.
  8. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    i agree, the shelflife is good. the key is that skin that develops. we buy qrts at work, as long as you clean the seal area up like new it lasts a long time. leave some down in the seal and you practically have to mangle the can to get it open again.. i've seen guys try using saranwrap under the lid, etc, doesn't work... ya just gotta clean it good..
  9. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    POR-15 is the best.
    There is another product called Rust Bullet (just like POR-15 at the same price), and another "primer" type product that must be topcoated made by a company called Wasser (Wasser MCMIOZINC) that is 40% cheaper than POR-15. All of these are moisture cured urethanes.
    A small step in ability, but a big step in cost down from there is a product called ZERO RUST. It is not as mean as a moisture cured urethane, but is adequate for what you will prob. need and is a lot cheaper. It also comes in a spray can for those hard to reach areas if you don't have spray equipment.
    COSTS
    POR-15 $95.00/gal
    Rust Bullet $95.00/gal
    Wasser miozinc $58.00/gal (must be topcoated)
    ZERO RUST $36.00/gal $6.25 in aresol can
    I have used them all in the past 6 months.
    POR-15 and Rust Bullet are nice because they are a 1 step, mean-ass, never have to do it again product.
    The Wasser is good as well, but needs a topcoat of something (any spray can topcoat will do). It gives you POR-15 results @ a little less $$.
    Zero rust is a close second to the moisture cured urethanes at a lower price, and leaves you w/ more beer $$$.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  10. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    hmmm, we pay about 16 a qrt for POR 15 if memory serves me correctly... guess we're getting a decent discount then... i'll have to remember to check retail next time i order it.
    tell ya what, that stuff goes a long way..
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    [hijack]
    i want to use por-15 on my frame and im trying to figue out how much i need. a 4 ounce can covers 12sq ft. i think i need 1 quart and 1 pint, 48 ounces. think this is enough or should i buy a gallon? oh yea im doing a long bed and probably the axles also.
    [end hijack]
  12. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I sprayed my Vette's new frame with rust bullet then top coated it with stain black paint.
    I haven't ever used POR15 so I don't know about its durability versus Rust Bullet.... but I have my own test going on in the back yard and the rust bullet seems to resist rust fairly well--- a lot better than normal paint and it is significantly harder than normal paint.
    I bought Rust bullet because it was cheaper than POR15(only by a little) and Plus it is aluminum coloured so I can paint paints and leave them aluminum or buy some cheap topcoat and paint them a different colour.
    P.S. I used 1.5 quarts when I sprayed the frame.... with a lot of waste( I tried to use a garden sprayer to spray the inside of the frame rails)
  13. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    The por-15 is so tough I spilled Aircraft stripper on my frame after it was finished and it did not hurt the por at all /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  14. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    Sidepipes, just so your aware for the next time, if you want to try out the POR 15, it is available in silver. probably very similar to the Rust Bullet i would assume..
  15. widowmaker
    widowmaker Registered Member
    Nov 26, 2003
    58
    westfield,mass
    por-15 is great used it on my axles and even the road salt can't touch it but i warn use dish washing gloves cause once its on you it takes quite some time to get off the skin and the can will last long if youdont use it all if you put a plastic bag between the lid and the can hope ever thing works out /forums/images/graemlins/thumb.gif
  16. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    por-15 is the $hit i did my frame and axles with it. it is very tough! as for coverage i put 2 coats on a lwb truck frame inside and out including all xmembers and spring hangers as heavy as i could and it took about a half a gallon! /forums/images/graemlins/grin.gif
  17. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    how did you apply it?
  18. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  19. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    How much of a PITA was it to do the whole inside of your K5? If you had to do over again, would you have done the whole inside or gone another route?
    Kris
  20. stretch67
    Nov 1, 2003
    171
    bozeman mt
    i used a brush! it is self leveling even on vertical surfaces. you can spray it but it sounded like a pain and don't use the ggod spray gun ! also don't let it dry on your skin (don't wear shorts when applying i never said i was smart! they should call it does not come off skin when dry !) /forums/images/graemlins/grin.gif
