Any help on a rear dana 44 question?
Discussion in 'Other Rides' started by dyeager535, Feb 6, 2007.
  1. dyeager535
    26,977
    Friend has a 1970 International Pickup truck with what he says is a dana 44 rear end. It's posi, unsure of gear ratio. I assume he is right with the D44 comment, since he put the posi unit in it.
    Am I correct in thinking Jeep folks use these axles a fair amount?
    He's planning on taking the truck to the wrecking yard running complete (bad clutch which is apparently impossible to get, truck not worth the money/work) but I figure if the D44 rear or the posi unit is worth something to Jeepers, (assuming the posi would work in a front D44 as well) I could put it on craigslist for him.
    Any input?
    Thanks!
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Yeah, Jeep guys would be interested in both axles actually. Where are you located?
