Any homebrew ways to get bearings off a carrier
Discussion in 'The Garage' started by 8_YOUR_H2, Apr 27, 2007.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I don't have a bearing separator set nor do I want to buy a set (and no parts store near me rents them...I give up!)since I will never use them again. Are there any home brew ways to get the bearing off the carrier with out totally destroying everything? I would like to keep the shims intact for the new locker I am installing and sell the old LSD.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    if u are not worried about saving the bearing, u can knock the ring & rollers off. then take a cutoff wheel & score the race on both sides. then take a BFH & a chiesel & hit it in the score & it will split, then u can pull it off by hand or it will break in 2 & fall off.
    the deeper u score it the easier it will break.
    p.s. wear saftey glasses. at least when u hit it, races are very hard & will chip.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What about an air chisel behind it ? Seen it done that way before .
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    I cut them with a cutoff wheel then once the bearing material is really thin I either press them off or hammer them off. Just be really careful not to cut the carrier (it won't ruin it, but it will increase the chances that a bearing will spin on that journal).
