Any ideas how to do a 3" body lift w/9" suspension?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jul 16, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Any ideas how to do a 3\" body lift w/9\" suspension?
    Do you guys have any ideas on how to lift the body from the frame when I go and put my 3" body lift on? I have a 9" suspension lift already on it. I don't have a clue what I'll be able to do to get it off the frame. There isn't a floor jack that's going to reach the floor of the truck. Any suggestions? I thought about using our chain hoist and hooking up sides of the truck and doing it like that, but I'm not sure where to hook the chains to. I'm stumped boys!
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  2. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Re: Any ideas how to do a 3\" body lift w/9\" suspension?
    I used a floor 2 1/2 ton jack and a 4x4 piece of wood on each side and had no problems. What kind of drive shafts and steering problems are you having with the 9" lift? If none, what did you do!!!
    Eat More Mud!!!
    Dreaming of a BIG BLOCK!!!
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Why don't you take the tires/wheels off and lift it like that? Or put some stock wheels and tires while you lift the body?
    <a target="_blank" href=http://www.chriswhitley.com>www.chriswhitley.com</a>
  4. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    use a strap in the rear 1/4 panels of the truck then one right in front of the doors that should work
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  5. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I put cement blocks under my floor jack and a small 4"x4" to lift the body. I first tried the floor jack and a 3 foot 4"x4" but it got a lil shakey.
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  6. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    I'm not having any driveline problems or steering problems. I used shims cut at a 6 degree angle, t-case drop, and lengthened drive shafts. The front axle has a 2.5 degree shim and works fine. I haven't had a problem with them yet. The steering was simple. 2" drop draglink, 2" pitman arm, and 4" steering arm. Works like a charm!
  7. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Where'd you get the shims for the axles?
    Thanks,
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  8. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    You can get them from ORD I think and the ones that I have now are from Superlift. Call one of the mail order places and I'm sure they can hook you up.
  9. AGM73k5
    1,246
    Portland OREGON
    Cool thanks for the tip :)
    -Aaron
    ___ __ _ _ ____ __
