Any ideas on how to remove tacky glue from instrument panel...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kwcdawgfan, Feb 22, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    My 73k5 had a cheapo wood grain cover glued to it and I removed it last night with the intention of painting it black... Problem I am having is getting the glue off... Tried finger nail polish remover and have it soaking in mineral spirits right now... Hope that works but if not could use some ideas....
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    I'm not sure about the type of glue, but WD40 takes off about anything off of paint, not sure about plastic. The only other thing I know worth a crap is GOO or OOPS. Can get either at store for cheap, and it has numerous uses around garage and house.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. bushwacker
    bushwacker Registered Member
    Sep 8, 2000
    58
    Orange County, Calif.
    Try goo gone or citrusolve, both work great and are probably the same as previous post but named differently in diff parts of the country.
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    If those don't work, try some 3M Adhesive Remover. I think the Ace Hardwares carry it. If you are using it on plastic, test some on a hidden part first to make sure it doesn't melt the type of plastic you are removing the glue from.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  5. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i used "goo off"
    it worked great. it was to put it on the rubb off, untill it comes off. i put it on, let it sit, then i came back and rubbed it, it was easier.
    but REALLY easy removal would be to use acetone.
    pure acetone is bought at lowes by the quart or gallon. fingernail polish remover is like 75% acetone. and it works too.
    <A target="_blank" HREF=http://www.geocities.com/confederatek5/>http://www.geocities.com/confederatek5/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
