any ideas?
Discussion in 'The Garage' started by Randy92782, Apr 22, 2007.
  1. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    ok so i bought a truck. took off the front and rear diff. covers to see if maybe the gears matched. here's what i found. here's the front
    thought it was a locker but have no idea what kind?
    here's the rear
    think maybe it is a limited slip. thanks for all ya'll's help
    pretty sure the gears are 4:10's but here's the numbers
    Front- 3 3 82 Dana D 18520 A30295 45 11 <<that's why i said 4:10's
    Rear- 1 GM _74014 9 37 2 83 <<not sure about rear
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    limited slip in the rear for certain. Can't tell on the front, any closer pics?
    and is that a lift block on the front?
  3. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    yeah unfortunately it is a lift block on the front. it's gettin removed. if u only saw what they had as a lift in the back. they had 2 four inch lift blocks stacked.....yeah kinda what i thought. talk about dangerous and stupid.
  4. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i call gov bom rear. as it looks like it has the fly weight shaft in it. and the front possible old style power lock or trac lock of some kind.
  5. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    Yeah I was gonna say gov bom too!
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I would say gov lock or G80 locking differential for the 14bff, and maybe the Dana is the Powerlok.
  7. sweetk30
    Nov 1, 2004
    25,536
    533
    that is not a 14ff rear by far. possible 14sf 9.5 rear.
  8. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Your front axle is a Dana 44, 4.10, and either an early Auburn gear limited slip, or early True-Trac---Both good posi's.
    Your rear axle is a 14 bolt semi-floater; That is to say the axle shaft is NOT full floating, as would be a 14 bolt full-floater
    4.10 gears, and a gov-loc--not a very desirable rear end, and a rather weak form of limited slip.
    Jimbo
