any ideas?
Discussion in 'The Garage' started by schmuck, Dec 29, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    i had a set of hedman headers on my truck that continualy leaked so i finaly got a new set of flowtech try y headers and they still leak, its just the drivers side at the head that leaks ive tried cleaning the header flange with a wire wheel and ive tried cleaning the head with a wire wheel and scraper, ive used the paper gasketes and the steel reinforced gaskets please help this is driving me nuts next i was going to try exhaust manifold gaskets
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I used exhaust manifold gaskets and they always worked really good. The only leaks I got were due to loose bolts...
    I used the dead soft aluminum collector gaskets and had good luck with those as well.
    Rene
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Does it leak from the begining? If not it could be the bolts are backing out. I put some header bolt locks on mine when I had them and they lasted for years. PITA to put on but worth it.
  4. schmuck
    Nov 11, 2002
    523
    yeah they leak from the get go, ive got dead soft on the collectors those things are great, i dont know what happened it never leaked then one day it started leaking and i havent been able to get it to stop yet
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    warped head? same side leaking as before???
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    huh i dont seem to ever have leaks from the head..mine are all in the collectors due to warped flanges..and i used the dead soft aluminum gaskets to..on the heads i just used paper mr. gaskets and they seem to be fine i dont ever hear any ticking coming from them so..
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Does everything line up square? Did you way overtorque the flanges????
  8. schmuck
    Nov 11, 2002
    523
    i didnt over tighten as far as i know, i cranked down on it with a stubby wrench, as far as the head goes it didnt look bad but the next time i pull it off ill check it with a straight edge
  9. schmuck
    Nov 11, 2002
    523
    and im retightening them after about 2 days
