Any interest in a sandblasting/POR-15 frame restoration article?
Discussion in 'The Garage' started by Desert Rat, Jan 7, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'm in the process of redoing my frame. I bought a Sears sandblaster and just finished cleaning the frame. Next step is the POR-15 frame kit including POR-15 undercoat and chassis paint. I'm shooting pics through the process. Anyone have any interest in an article on the project?
  2. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    sounds good...I may do that as soon as the temp rises here a bit
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Count me in, I plan to do this soon.
  4. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    heck! i'd like to see it.where's tri-valley?have fun /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Dublin, Pleasanton, Livermore. More than a few Tri-Valleys about I imagine. I will shoot some pics of the blasted frame today and will be starting the POR-15 base coat as well. I'll try to write it up soon.
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I'd like to see that.....
    I've got a sandblasted frame sitting in my garage, and I'm in the process of blasting the inside of the cab...not sure if I want to use a POR-15 or an acid-etching primer to seal the fresh metal though....
  7. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Definatly interested. Are you doing this with the body on or off the frame?
  8. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Great idea for an article.
    I'd like to read it!
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i plan on starting next month so i could use the foresight.
    nathan
  10. Gavmaster
    Gavmaster Registered Member
    Nov 18, 2002
    10
    Vancouver, BC
    I'd suggest the primer...
    POR stands for "Paint Over Rust":
    it doesn't adhere well to fresh metal.
    Gavmaster
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Well, I just laid the first coat down of the POR-15. I will do the second coat here in about an hour. I have to say I am very impressed. Just with one coat it already looks great. Almost a powdercoat type plastic look finish. I disagree that it doesn't adhere to bare metal well. In fact, the brochure says it will do very well with sandblasted bare metal which is what I have. After the second coat dries, I will then be painting it over with POR-15's Chassis Black. They aren't kidding when they say that once on your skin, only time will remove it. So far the project is going well and I am taking pictures along the way. I will have to save out the areas that need welding for later. I thought about waiting until all the welding was done first before painting but I didn't want the bare metal to start rusting again before I got around to painting.
  12. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Oh, and I am doing it with the body completely off and everything stripped off of the frame. I will try and insert some pics as soon as I get myself a web site, which I've never bothered to do.
  13. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Sounds like a great idea for a write-up. I am definately very interested in it! I'd like to see how it comes out and how much you use to cover the whole frame.
    Kris
  14. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Did the Chassis Black coating today. I plan on doing the write up as soon as possible but if anyone just can't wait, pm me or send me an e-mail and I will send you the pics and some suggestions.
