Any ladder guys?
Discussion in 'The Lounge' started by Can Can, Apr 13, 2005.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I need to buy a 24' extension ladder, but I'm a little confused about the ratings..... A class 3 ladder is rated for 200 lbs. The same ladder in a class 2 rating is almost double the price and is only rated for and extra 25 lbs??????
    Is the class 2 that much better? FWIW, I'll be using it for light construction projects, painting, and tree trimming at my rural recreation property.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Buy the lighter duty one and make sure the ground is clear around where you may fall
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    im a big guy (250lbs), so its always been class I or IA ONLY
    wouldnt trust anything smaller
    My method, (expensive way) is take your weight, or the weight of the biggest person who will go up the ladder, and add 30lbs, then round up to next class
    a good test, if you can arrange it, it to climb to the top of whatever ladder, as see how stable it feels to you... i have the feeling you'll see why price is so much higher for higher classes
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  5. Can Can
    15,552
    136
    Yeah, I already found that page during a search. I was just looking for some real world advice, because I read somewhere that a ladder is tested at 4x it's weight rating, kinda like I test underground gas lines at 770 KPA(about 110 PSI) even though the system it's installed in is running at 60 PSI.....
  6. Can Can
    15,552
    136
    I'm going ladder shopping this weekend. Thanks for the tip about testing them out. Is there any brand in particular you would recommend?
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Well, we must ask ourselves W.W.B.D.? What would Bubba do? Here's what Bubba would do. Bubba doesn't climb ladders. Bubba doesn't do heights unless he is hooked up to a rope hanging out of a chopper. Heights don't agree with Bubba. So when there's some ladder climbing to be done around the old homestead, Bubba calls in favors or pays some dinero for someone else to go ladder climbing.
    I hope that helps..................... :D
  8. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Monkeys are good at climbing
  9. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Southern real world advice. Just make sure you eat all your veggies and you'll grow up to be big and strong. Also, onions make you purdy, collards bring you wealth, and black eyed peas are for luck. :xmas:
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I can't recommend any but I can tell you to stay away from this one.
  11. Can Can
    15,552
    136
    HARDEE-HAR-HAR!!!!! You guys are hilarious.......:mad: :wink1:
    I guess I should have expected this kind of response from a bunch of goons, eh?:rotfl: :rotfl:
  12. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Little Giant Ladder
    I am not sure if this would work for you and they are abit pricey. Shop around online you can find them cheaper.
  13. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I think I heard, read somewhere that you should buy the ladder that will be rated at your weight plus whatever you might be carrying up and or down said same ladder.
    Having said that I've seen some pretty damn bowed ladders that I thought wouldn't hold but just kept bending and bending back, over and over so......
    Oh yea, I try to stay with fiberglass over aluminum. :)
  14. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    You gotta figure there is a large margin of safety in these things; there is a lot of liability if they fail. Also, the ladder is going to be stronger the closer it gets to the vertical position, since that will reduce the bending moment. I definitly would not spend double for a lousy 25lb higher rating. Kick it a little closer to the wall and call it good.
  15. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The higher class ladders FEEL ALOT sturdier when you are 20+ feet above the ground. I have one cheapo alum ladder and 2 good fiberglass Werner ladders. The Werners get used for anything above 10 feet. Only down side to fiberglass, they can break the ends if they fall over, alum will just bend or spring apart,
  16. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Little Giant or Gorilla ladders are my favorite... they are 1A rated and are adjustable to 4 positions or saw horse position where you take the 3 pieces apart, add a support for the extension pieces, and you have yourself a full size saw horse pair.
  17. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Ladders are set up to a 4-1 ratio. For every 4 feet vertical extend the ladder out 1 foot from the wall. OSHA safty standards.
  18. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
