Any magic techniques to remove a broken bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jed, May 26, 2002.
  1. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    My power streering pump top pivot bolt is broken off in the head. I should have noticed this when I bought the truck - never inspect a truck in the rain I guess. The pump works but its pulley is couple degrees off the plane of the water pump pulley and it squeaks peroidically hinting at a bearing problem or rubbing. Right now the top of the pwr steering pump bracket is resting on the water pump and is too close to the block by the looks of it (belt tension pushes it that way). I suppose I could just wedge the correct spacer between it and the head and hope it stays put (PING as it goes into the fan and through the rad. Ok bad idea.)
    I'd like to set this thing up correctly esp. if it's eating the pump bearings. The broken bolt in the head looks like someone had a go at it with an E-Z out or similar so it's only got a couple mm around the edges for 1/2 a cm or so. How deep is this hole? Will a machine shop or engine builder have any 'magic' ways of fixing this problem while the head is in the truck?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Drill n e-z out or r&r the head and send out to machine shop
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    EZ out...
    Rene
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If the bolt broke because it was overtightened or because it came loose then rattled and broke you should be able to get a sharp center punch and tap the bolt on the edge in the reverse rotation to remove it and it should start to move. If the bolt doesn't want to move and you have enough access to it then you could weld a small bolt to the existing broken one and just unthread it.
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    " Any magic techniques to remove a broken bolt?"
    I think I read about this in Harry Potter. Tap it twice with your wand and mutter expeliamos! Hope this helps
    tom
  6. Jed
    Nov 3, 2001
    60
    Alberta, Canada
    Expelaramious! Darn, it didn't work. I'll have a go at it with and EZ out. Thanks.
  7. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    you might also want to pour/spray some penetrating lubricant on it (maybe it'll make your task easier?)
