Any news on the NEW Doubler for the SM465 tranny?
Discussion in 'OffRoad Design' started by Depdog, Oct 20, 2002.
  1. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Title says it all.
    Depdog /forums/images/graemlins/1zhelp.gif
  2. Depdog
    1,657
    Georgia
    Well????
  3. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    hey depdog, what did you hear?
  4. Depdog
    1,657
    Georgia
    NADA /forums/images/graemlins/frown.gif
    And we aint talkin blue book
    Depdog
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I haven't worked on it much the last couple weeks but should have some time this week to play with it some more.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I'll be waiting on some new 465 tech too.
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    What is 'new' about this doubler?
    I too have a 465 and would like to here what you are waiting for from ORD?? Sometime next year I'm thinking Doubler!
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
  9. Depdog
    1,657
    Georgia
    Stephen, any news on this one? If this becomes available, what parts will we need to get besides the kit you are working on.
    Depdog
  10. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    DepDog,
    Wish you would share some more info with the rest of us onlookers!!! IS this for a 10 spline or 32 spline 465? Does it use the old 205 or the newer 6 bolt 205 and where can us, not so knowledged on this "New" Doubler, find out what you know? Thanks!!! /forums/images/graemlins/thumb.gif
  11. Depdog
    1,657
    Georgia
    If you read all the replys in this post you know as much as I do. I am waiting for info from Stephen.
    Depdog
  12. Batmanjr
    Mar 23, 2001
    1,537
    That's not much new news!!!! If I understand correctly, ORD already makes a doubler for the 465!!! The way they build them, All you need is a 203 to mate! Maybe he's working on a short 32 spline output shaft!!!! Tried that once, was too expensive! I don't know, seems hard to believe that much will be different! Althought, It would be awsome to use a 35 output of 420, and mate it with a "New 35 spline input gear for the 203!!!!! Just some ideas I've already thought of, just never had the funds!
  13. Depdog
    1,657
    Georgia
    He made one in the old Gen 1 doubler, he does not make one in the Gen II that will bolt up to the 10 spline 465.
    Depdog
  14. Batmanjr
    Mar 23, 2001
    1,537
    I thought all you needed was a 10 spline 203 and adapter!? I sold mine a while back and opted to go with the 32 spline, now I have all I need! And its' 30+ all the way to the wheels! /forums/images/graemlins/thumb.gif
  15. Depdog
    1,657
    Georgia
    Stephen, come on, give us the skinny. Are you still working on this or do we need to look at other options?
    Depdog
  16. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    3-4 weeks leadtime on the 32 spline 465 shaft that will work with the factory adapter housing. 32 spline input is a bolt in for the NP203, the gear is about $165.00. The 465 output shaft will be approx. $240.00. If you're interested, get an order in now for the shaft, I'm really not sure how popular it's going to be.
    The next step is building our own adapter housing which will be shorter than the factory housing by at least an inch. A complete kit with new adapter and shaft will likely run $550 or so.
    There you go. Now we can do 32 spline all the way through on a 465 AND with a reasonable length adapter housing.
  17. Depdog
    1,657
    Georgia
    O.k. let me see if I can get this straight. You can take any Sm465 2 or 4 wd and you have a new 32 spline main shaft for it.
    Then you take an 203 range box and put in a female 32 spline input gear.
    This is for use with the factory SM465 to NP203 adapter, and you are going to build your own SM465 to NP203 adapter that will be shorter. The new main shaft (32 spline) and the new adapter will run around $550.00, then you need the 32 spline input gear for the 203, a 203 reduction box and the doubler kit, plus a th400 np205, or have the 205 you have modified to take the th400 input gear and bearing.
    Is all that right?
    Depdog
  18. Batmanjr
    Mar 23, 2001
    1,537
    I don't know about around you guys, but 203 range boxes here are plentiful with 32 splines!!!!! I picked up my 203, 32 spline for $150! Are they rare or something? I don't know this part!
  19. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You've got it dep, that's the recipe for a 32 spline SM465/203/Doubler Kit/205.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    this sounds like a great addition to your lineup.
    the 10 spline mainshafts are usually worn out so I think there is a market even if it can be made to mate a 32 spline 205
