any one ever change seals in a np 205
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by asisco72, Aug 22, 2005.
  1. asisco72
    asisco72 Registered Member
    Aug 19, 2005
    11
    north florida
    i think i need new seals in my transfer case i keep getting tranny fluid in my transfer case my trans was just rebuilt and i thought that might help the problem but still getting fluid in transfer case bad trans rebuild or bad seal???
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    did you change the o-ring seal too? you also have to be carefull when you put the two back together without damaging the o-ring. any pitting along the seal contact? also did you lubricate the seals or run them dry?
    I am assuming you have the th350/np205 setup.
    ARQ.
  3. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Mines leaking also but from the front output shaft. :(
    I'm hoping I can change it while its still in the truck, anybody ever tried it that way?
  4. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Have you checked/changed your seals yet?
    How'd it go?
