Any one good with electrical problomes?
Discussion in 'The Garage' started by dodgetruck91, Mar 7, 2004.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    ok, i got a 88 k5, its been siting for 2 months, it fired right up, let it idle, and i switch on the lights, and it jusut shuts off. no lights go on either, it then is extremelty hard tot oget goin after that, i have to turn at least 10 times with eather. any help is great /forums/images/graemlins/k5.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Bad ground. With the lights off the body is pulling ground though the harness. When you turn the lights on that path to ground is lost.
    Back side of the passenger side head to the firewall is a ground strap. It's either corroded or the motor has been out and it was left disconnected.
  3. dodgetruck91
    Oct 22, 2002
    99
    is it in front ofo the firewall just under theh cowl?
  4. Grim-Reaper
    7,385
    Atlanta
    Yeah. It bolts next to the blower box up behind the head. REAL easy to miss. It's real hard to see it.
    It's a braided strap. It has to hook the body to the block to complete the ground path.
  5. dodgetruck91
    Oct 22, 2002
    99
    ill check it out in the morning, thanks.
