Any one here running Rod type (mechanical) clutch linkage?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big'nBadK5, Aug 15, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    Putting in the pedals today and need to know where to cut the hole in the truck for the rod to pass down to the Z-bar. thanks. /forums/images/graemlins/thumb.gif
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Install the z-bar, make a mark on the firewall right in front of it, ceter punch it and drill a hole. cut a 1" x 2" hole with the starting hole in the center.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I put a mechnical clutch sm465 in a 1973 auto cab.
    There was an indentation right where it needed to go.
    Get a hole saw and get after it.
    You should use the stock rubber boots to cover the hole or it will let in a lot of noise...and smells. Take my word for it /forums/images/graemlins/smile.gif
    -- Mike
  4. dyeager535
    26,980
    His truck is designed for the hydraulic clutch assembly, no indentation in the floor.
