any one interested ina 77 chevy step van
Discussion in 'General Parts for Sale' started by bryguy00b, Nov 29, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    -this is a friends hes trying to sell located in Greece N.Y PM me if ur interested in this ..thanx
    1977 Chevy Step Van P20
    Monroe County Sheriff's vehicle, Mobile Mechanic's Van
    Drivetrain:
    . 30K Miles on 355 ci Small Block Chevy
    o Ported stock heads
    o Ported exhaust manifolds
    o K-Line Bronze Valve Guides
    o De-Tuned with a milder cam (the engine was in a car)
    o Flat-Top Pistons
    o Stock Rods, 0.010 under crank, Clevite 77 Bearings
    o Ported Rear Main cap for better oil flow
    o Oil galleries in Engine Block Smoothed and Ported
    o Oil Gallery Soft Plugs Replaced with Threaded NPT Plugs
    o Deck and Heads Skim Cut for Flatness
    o Performance 3-Angle Valve Job
    o Q-Jet Carburetor, Hei Ignition
    . Heavy Duty TH400 Transmission, 105K miles
    o Shifts Strong, with a Kick
    o Adjustable Vacuum Modulator
    o Torque Master 2000 B&M Torque Converter
    . Corporate 14 Bolt Rear End, 4:56 gears
    o Brakes and Wheel Bearings Replaced and Serviced Last Year
    Body:
    . Custom Instrument Panel
    . Paging Alarm System
    . 120v Circuits Run Throughout, ~11 outlets , 3 are outside,
    Fluorescent
    Lighting (4) 8ft 96 watt bulbs, 3 Control Switches for 12v dome
    lights
    . Side, Front, and Rear Auxiliary Lights Controlled by Separate
    Switches
    . Trailer Marker Lights Controlled by a Separate Switch
    . 6 Pole Trailer Plug needs the Auxiliary and Brake Wires Switched
    . Full Sized Spare Tire
    . Full Insulation, except doors and floor
    Extra Goodies:
    . 4 ?" Wide-Opening Vice Mounted on Rear Bumper
    . Pipe Vice Mounted on Rear Bumper
    . Custom Extra Heavy Duty Rear Bumper, Subframe, and Trailer Hitch
    Receiver
    . P30 Rear Springs, 3-4 years old, By Thruway Spring
    . Steel Table with Wire Wheel and Grinder Mounted
    . Interior 3 ?" Vice Mounted
    . Lots of Shelves, Cabinets, Fold-Down Work Table
    . 24 Drawer Craftsman Roll-Around Toolchest, Installed
    . 2 year old Undercoated Gas Tank
    . New Lower Ball Joints
    . Dual Horns, Air horns
    . Front Winch Pad and Receiver for Manipulating Trailers, Pulling cars
    onto
    Trailer
    This Truck Makes for an Excellent Service Vehicle, complete with
    plenty
    of outlets and lights, Tons of Shelving and work benches, has as much
    utility as a Garage!
    I'm looking for $3000 for the whole thing. For just the body with the
    following accesories still attached:
    Body:
    Fluorescent
    lights
    Extra Goodies:
    Receiver
    onto
    Trailer
    plenty
    I'll sell for $950 See the attached pictures.
    http://coloradok5.com/photos/data/500/4903BigWhite4-med.jpg
