any one moved there steering box back?
Discussion in 'The Garage' started by supersize75, Jan 13, 2004.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I am thinking of moving my steering box back, looks like 8-9 inches and just turning mt pitman arm around,
    I have cross-over now so I imagin this should work now?
    Also I started my double u-joint steering shaft so I think nothing is stoping me right? /forums/images/graemlins/ears.gif
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Why...what would the benefit be?
  3. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Hmmm, I bet that truck will be very interesting to drive after that mod /forums/images/graemlins/thinking.gif
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are you talking behind axle steering style. The drag link will hit the engine x-member good if you move the box back, neat idea but a hell of a lot of work. The frame has to have similar dimples on it to support the load, and have the box mounted flat.
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Wouldn't the steering be backwards if you did that? You would turn your steering wheel left and the truck would turn right. /forums/images/graemlins/crazy.gif
  6. supersize75
    Sep 27, 2002
    2,638
    Sorry I just realized I didn't say anything about wanting to move the front axle forward, just thinking out loud, I am really just looking for some sollution to a permanent frame fix, as for the demples for where it mounts..I don't think haveing the steering a inch over will make a difference with using a double u-joint shaft.
    Also I want to move the rear axel forward, just need to figure out what coils have what spring rates /forums/images/graemlins/confused.gif, or if it will be easier to just run 63's like most are sugusting..but then my departure angle is robbed. /forums/images/graemlins/thinking.gif
    I dunno just looking into ideas at this point, I started reading up on 4 links, anti squat and roll axis and I have a LOT of reading to do. I have gained a new respect for those who can build and design a suspenion that works!
    I am considering putting the truck down for a couple of monthes a doing a complete rebuild on it...again.
    /forums/images/graemlins/thumb.gif
