Any one out ther put 88-up wheels off of a k2500 onto a 1976 14ff?
Discussion in 'The Garage' started by Klink K5, Dec 1, 2002.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    I want to put factory 16 inch wheels off a 1999 K2500 surburban onto a 1976 chevy k20 pickup. My question is that I want to use the factory center caps that require the lug nuts with the threads on the outside required to hold on the center cap via the the black screw on caps that go onto the lug nut. The lug nuts are metric and I would like to know if anyone has taken the time to figure out the proper studs required to make this all work. I have a 14 bolt ff in the rear and a dana 44 full time in the front. Thanks /forums/images/graemlins/thumb.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    check to make sure the backspacing is correct. i know i tried to fit a early 90's chevy IFS onto a solid front axle and the rim would hit the tie rod. my .02
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I did this on my 79 Sub. Put the late model Alcoa forgings on it. Didn't use the late center caps or the lugs as that's just more stuff to rattle and fall off. The guy I got the wheels from did put all of that stuff on his wife's Sub though. He ran the correct tap into the metric nuts. He's not the type to do something half-a$$ed so I'll bet the threads are really close to start with.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The studs are 9/16-18, and the nuts are M14-1.5.
    9/16" studs are about 14.3mm.
    1.5 mm/thread is about 16.93 threads/inch.
    I don't have much faith in cutting a different pitch thread on 0.3mm of meat. I'd be looking at getting studs from a newer truck to fit my older hubs/rotors.
    The newer (88-up) 8-lug steel wheels are as soft as butter compared to the old steelies. They bend VERY easily. Look for F0RD (aka Accuride) 16x7 wheels. They're the strongest 1-piece steel wheel in production.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The backspacing is fine, and the wheels will bolt right on. Somebody makes the 9/16" lug nuts with the threads on the outside for those type of center caps. I will search around a little, and try to find out where you can get them. There actually might be a GM part number that will work, as I think they used those type of caps while they still had 9/16" studs.
  6. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    what i did is put the regular eggcorn 9/16 lugnuts on and found hub caps from a 89 3500 pu the are spring loded deals that pop over the eggcorn style lugnuts so no need to change to a 14mm with the outer threads done it but no pics yet BTW i have 38.5x11 boggers on those same rims its a pretty good look i might add...... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/usaflag.gif
  7. Klink K5
    Aug 3, 2002
    549
    Northwest Iowa
    Thanks for all of your Ideas! /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/rotfl.gif
  8. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    So we're talking about 17tpi vs. 18 tpi and .011" larger diameter. That sounds to me like several to many threads will not be changed very much by the tap, and the engineering rule of thumb is that you can't expect more than three threads worth of thread engagement due to the manufacturing tolerances of the threads involved. I'd call it very close to being statistically indeterminant.
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    YES they will work!
    I installed a set of chrome steel wheels from a '99 K2500 onto my '88 crew cab with dana 60 front. No mods everything fit.
    Used the factory caps, bought the custom nuts required. Currently I am using factory center caps on my '91 suburban with Weld aluminum wheels, looks much better than the weld centers. You will need to cut the centers out of two caps too clear the lockouts, I did this on a lathe.
    I also have 4 steel wheels with trim rings that were take-offs from a '99 K2500 "classic" crew cab.
