Any one running an electric fan?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FRIZZLEFRY, Jun 4, 2001.
  1. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    When I do alot of crawling on rocks or climbing hills (high RPM low vehicle speed) my temp gauge will hit 230.In stop and go traffic it runs abuot 160.Part of my problem is that I have no fan shroud,none of the wrecking yards around here have any.It doesnt overheat but 230 just dont sound good.I was thinking of running an electric fan along with the engine driven fan to get some air flow at low speeds.What do yall think?
    All work and no beer makes Frizz a dull boy
  2. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    i run a eletric fan when i go rock crwling my truck has a fan shroud but with the added heat of hedders and my air compressior it get warm i run a far off of a nissan sentra it is what i had
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Well I finally 'battle tested' mine last week. I have a stock IROC electric fan and shroud mounted inside the engine compartment as a puller, in front of my 4 core radiator. No other fan. Had a 93 degree day here last Thursday and sat on the freeway for 45 minutes going 5 mph on my way to meet elkboy to deliver the steering stabilizers............never got over 190 degrees the whole time.
    Pretty happy with it now..............that was a good test, and the first real heat test it got since we put it in during the motor rebuild last fall.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  4. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Frizzlefry,
    I run dual electrics on top of a good belt fan w/ shroud. I have themostat of electrics at 185. They rarely come on except in sit and go traffic and dam hot days. I had some clearance problems, so I had to zip tie (military hand cuff size) the fans to grill. Works great. I think they were only 12" fans too. LOL (Luck)
    If you ain't hurt, you ain't playin' hard enough.
    The General
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Wow this has been a HOT topic lately, heheheheh get it HOT topic....slap sorry[​IMG]
    any hoo I run elctric only and the fan that keeps me cool in the California Heat is the Flex-A-Light BlackMagic M150 rated at 2800cfm. I also use the Summit HighFlow water pump and my temp never goes above 200 with my 3row rad and 100 deg summer days. Good Luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  6. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    I run two small electric fans and one large one with the big block i run at 180 degress
    <A target="_blank" HREF=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </A>
  7. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Isn't this board awesome??? I have a bunch of electric fans in my back yard from various GM vehicles, originally picked up for my S10. I've been tossing around the idea of stuffing one or two into the K5 for a couple weeks now, but my worry was that it would underperform the clutch fan. I never even thought of running both!! Y'all are great!
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  8. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Thanks for all the input everyone.Ive got that same fan youve got Steve ,brand new in the box waiting to go in my 68 Mustang.I think I might put it on my K5 and get another one for the Stang later.Thanks again guys.
