any one running electric radiator fans
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Apr 3, 2001.
    been contemplating an electric fan or dual fans and want to get comments good or bad on them. i have a 4 core and don't have any overheating problems. i like the idea of being able to turn them on or off depending on conditions.
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  1. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I'm running two black magic electric fans on my BBC. I also use a custom Be Cool rad. I've been told that this will be more than sufficient to keep the water temp at 180. Now if the thing were only complete........ The maker of the Black magic fan has a dual version that they claim will keep a BBC cool. It does require the large diesel or big block rad though. If you go this route you need a high output altenator and upgraded wiring to handle the load of the fans, lights, wipers, heater fan etc.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am using the single Flex-A-Lite Black Magic M150 (few that's a long name) anyway the thing works GREAT! I have a 3row and mildly built 350 with a Summit highFlow water pump and my rig has 0 cooling issues even in the Valley heat of 105 my rig never goes above 200. In the winter I am barly using the fan at all. I do sut it off when on the Hwy so the trick for me is to remember to flip it back on when I pull of the freeway......I've had it for a couple of years now and it seams to be worth the 180 bucks. Plus it was the highest rated single fan I could find at 2800cfm...
    Good luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I have the Duel Flex A Lite fan that was mentioned above, I will be installing it soon and can let you know how it performs them.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <A target="_blank" HREF=http://depdogsk5.coloradok5.com>http://depdogsk5.coloradok5.com</A>
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am runnign one elec. and the normal stock fan. Make sure your radiator is in good shape and clean inside before swapping to an elec. My rad is a tad small and I need the mech fan also to cool. My elec is a 16" fan..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    On my 406SB am running an IROC electric fan with my 4 core radiator. No problems with cooling, so far no issues whatsoever. If you and I make it to the TSF or Sand Lake run on April 14th (not sure if I can yet) you can see my setup. Don't have mine setup yet for manual shut off but it is a very simple thing to do.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    this is on my to do list but they do work good you just need to get in the habit of turning them on and off
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  7. dyeager535
    26,979
    I think if you are having no problems, don't go to the hassle. If you are interested in having an additional fan, having it wired in with a switch so that it came on when engine temp was X degrees (so that it would prevent overheating above say 210) would be a good idea. The stock clutch fan flows a very large amount of air, and steals very little HP. Gotta remember that an electric fan runs off the engine just like a clutch fan, just takes a little less direct route. Probably more efficient in that regard than the clutch, but how much is anyones guess. Other factors such as weight on the water pump, etc, come in, but thats all going to be heresay unless someone comes up with some tests.
    Dorian
  8. coham
    coham Newbie
    Apr 3, 2001
    3
    Pontiac, IL.
    I just recently installed one when I put a new 350 in. Love it. I haven't had any problems with it. Mine has the thermostat so it turns on and off automatically. You can switch it on and off manually though if you want. Wiring it up is easy and so was mounting it to the radiator.
  9. rubiconchevy
    rubiconchevy Registered Member
    Oct 29, 2000
    49
    Tracy,CA
    I have the black magic fan on my 73 Blazer and the thing works great. I have a 3 row rad. and run a zz4 motor with no problems. I have had it for about 5 years with no problems. You also get a little more power and better gas mileage by going to an electric fan. Not much, but a little is better than nothing.
  10. Grim-Reaper
    7,385
    Atlanta
    Found something good off Junk late 90's Fords. They have HUGE cooling fans on the T-Birds Musdangs and Lincolns.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  11. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    i yanked a 16" puller off a late model bonneville from the local boneyard, 15 bucks. got the adjustable thermostat switch from discount for another 15 and havent had a problem in over a year.
    runs cooler on the trails, not dependent on rpm.
    removed parasitic drag on motor, longer water pump life!
    good luck,
    MTPockets
    <A target="_blank" HREF=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</A>
  12. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If you can find a dual fan or a single large air volume fan you can run the electric and remove the belt drive fan. This will give you a little less drag on the motor and if the fans are right you should be better off than stock. But you gotta make sure your new fan/fans are/is going to give you the proper airflow.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  13. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Hey Emmettology, is your electric mounted as a pusher or a puller? I would imagine a pusher, but I've got so much room between the engine fan and rad. that I could probably mount a slim-line puller and get away with it...
    [​IMG] Semper Maintenance!
  14. Slim_Ruthless
    Slim_Ruthless 1/2 ton status
    Feb 20, 2001
    119
    Sydney , Australia
    I'm going to do the same thing with mine . Get rid of the stock fan & fit a single large or 2 small fans as pullers cause my home made alloy grill is a B%#$^ to remove . I think the Single large flows more .
    [​IMG] <A target="_blank" HREF=http://baulko.coloradok5.com>http://baulko.coloradok5.com</A>
