any one runnning 2.5 exaust?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2cocky, Oct 25, 2001.
  1. 2cocky
    2cocky Registered Member
    Oct 7, 2001
    59
    Southern Maryland
    Is any one out there running a true duel 2.5 exaust
    I am trying to set one up on my 86. I'm useing dynomax headers and an h-pipe but i'm haveing clearence prob. at the t-case. any ideas? thanks for the help.
    OOOPS....I THINK I JUST RAN OVER YOUR JEEP THING!!!!!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm running Hedmans/Flows with 2½" pipe, but no "H" - Not sure of the difference in headers, but on my 85 I've got tons of room around the T-Case.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    do you have any pic's of your exaust?
  5. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    im running true dual exhaust in my jimmy headers,2.5 inch galvanized pipes,40 series flowmasters and dump offs. sorry no H-Pipe cuz of the front driveshaft any ways the only way i could get rid of the clearance prob. i had to take it to a shop and have the guy run it along side of the inner side of the chasis, it looks great and i have zero clearance prob.
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'll snap a couple in the AM and post them for ya![​IMG]
  7. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    thanks
  8. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I am running dynomax headers and 40 series flowmasters on my 82. But no H -pipe .I did run into clearance problems at the t-case and had to have some custom bends made to make it work, I had the bends go toward the frame rails and up and to each side of the t-case so i can take out the transmission and t-case without removing the exhaust.I cant see any where a H pipe could fit on mine
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
  9. dyeager535
    26,977
    Not running headers, but heres a half ass shot of the factory diesel duals (either 2.25 or 2.5" never measured) on my truck. Passenger side is a little tight, but thats not even the right transfer case for those duals, and there is still enough room.
    www.dorianyeager.com/index2.html
    Why insist on counting when the ring gear has the tooth counts stamped in?
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i got 2.5 true duals with an H behind the t case , got pics if wanted ..
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  11. Speed-demon
    Speed-demon Registered Member
    Sep 12, 2001
    38
    Alberta
    For the price of getting your exaust sett up your better off just putting the headman headers on that will give you the clearence you need. Kill two birds with one stone.
  12. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    definately send them.
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I have true duals on the &amp;( running heddman headers and 40 series flows. I had a shop custom bend the whole system for clearance.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  14. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I run true dual 2.5" with dynomax headers. I have no clearance problems. I have turnouts right behind the rear wheels.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
  15. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Hedman headers, true duals with 2.5" aluminized all the way back through hi flow catco cats into 40 series Flows. Great sound.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  16. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Pic's of how I did mine with flowtech afterburners on my page, under exhaust work:
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  17. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Ya gotta great truck, neat site, and the potato salad hill run looked fun, even with the ramp shot...LOL !!!!
    83K5 Silverado
    What was that bump?
  18. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    Do you have the part # for the Headers?
