Any one use "pusher" electrical fans?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Dec 30, 2001.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Any one use \"pusher\" electrical fans?
    I am going to take off the mechanical fan and install an electric setup. I have the 16" ford 2 speed that I heard good things about and I got some other smaller ones. I am thinking about running 2 as "pushers". But as I think about it, what if like bugs, rocks, and mud fly in the grill and hit the fan. And when I wash it, would it cause problems. Does anyone have any tips for running a set of pushers?
    Brent
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: Any one use
    Yea dont. Run that ford fan as a puller and you will be happy. I run the ford fan on my Firebird and it doesnt overheat here in AZ in traffic in the summer. The hottest mine has ever gotten was 110 in the middle of summer.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Any one use \"pusher\" electrical fans?
    Running electric fans as a pusher derates their cooling capability by about 15%. Mount them as pullers if at all possible.
  4. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I am for sure going to run the 16" ford fan as a puller, but a hot rod buddy of mine says the one fan wont be enough and Ill need to run the one puller and 2 pushers. I am thinking with out the condenser in there and I have a new radiator (2 or 3 row, not the good one) that the one would be ok...I am only running 250-300hp with a SBC.
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    My TPI 383 runs cool with 2 pullers. But that's just dragging the K5 around. I've never towed with it. Towing can create low speed, high engine stress situations. This is when you need to be moving serious amounts of air. [​IMG] Idling along Colorado moutain trails in 4 Lo doesn't put much stress on the engine. [​IMG]
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I think DD and I are running the same fan, he lives in AZ. I live in Fla. 2 of the hottest states in the country. I dont have any cooling problems either. In fact my rig hasnt been above 160 deg. yet, (w/ a 2 row radiator.) and I drive it 30 plus miles to work. The temp just in the last week got below 80s -90s. (dont believe the weather channel...they say its been in the 70s to low 80s LOL!)
    BTW I run my fan on low speed right now. I havent got the A/C working yet, and dont need hi speed. When the A/C is hooked up, I will have it go to hi when the A/C kicks on.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Mines from a thunderbird super coupe. I havent used high speed yet (still need to hook it up) and I dont have ac anymore. I did with a mechanical fan and it never got above 110 with the mechanical fan.
  8. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Mines from a 4.6 'Bird. Prob the same fan. The shroud on the fan doesnt quite cover the whole radiator core. Theres about an inch or two on both sides.
    GO</a>
  9. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I'm gonna ask a stupid question-- but what the heck are you guys talking about? pusher's and puller's???? You mount fan's in your engine compartment other than the one that is already there? Why? I think I'm missing something? HELP!
    --Brandy
    LOVING the new Duramax!!!
  10. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    They're referring to whether the fan is mounted in front of the radiator or behind it. In front mounting is a pusher because it pushes the air thru the radiator cooling fins. Mounted behind will pull the air thru, hence the name "puller".
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  11. MudNurI
    Jul 15, 2001
    2,113
    VT
    But why do you put them in? I haven't ever heard of that, and don't think I have seen it either- I would have noticed I think? sorry for the ignorance- blame it on my hormones!
    Brandy
  12. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Re: Any one use
    replacing an engine driven fan with an electric one is usually done to free up the horsepower the fan is robbing from the engine, other advantages would be: it is only used when needed (controlled by a temperature switch, unlike the engine driven fan), the vehicle is quieter because an aggressive fan causes a lot of noise at higher rpm's, you can turn it off when 4-wheelin in mud or water to prevent fan from sucking mud or water into radiator core and plugging it up, multiple fans can cool better/faster than one engine fan in some cases ( the fan motors always turn the same rpm, so you still get good airflow when the engine is idling). Did I forget anything guy's?
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  13. Sparky87k5
    May 6, 2001
    726
    Re: Any one use
    You did good 95 Silverado. Another advantage is faster warmups in the morning because you don't have an engine fan moving cold air by the engine/radiator. Faster you get engine to 180-190, less wear and tear on pistons and cylinders you have. Nothing wears piston rings faster than a cold engine.
  14. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Re: Any one use
    I guess the reason I am doing it is because of the body lift. The mechanical fan is real close to the tranny lines now and I guess this is my excuse to spend more cash on cool gadgets[​IMG]
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Any one use
    Gee, seems to me that it would be a LOT cheaper to just re-route the tranny lines! [​IMG]
  16. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Re: Any one use
    I dont know, All 4 fans including the ford fan cost me $50 off of ebay[​IMG][​IMG][​IMG]
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Any one use
    Tranny lines cost about $5 each. [​IMG]
    Make sure you mount the fans to a solid point. Those stupid tie-wrap gadgets that push through the radiator will just saw holes in the radiator tubes. [​IMG]
  18. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    Re: Any one use
    One other thing, on some vehicles you could have a situation during a water crossing where the engine mounted fan gets flexed foreward by the pressure of the water, and rips out the core of your radiator. I don't know how easily this could happen to our K5's, but lots of other groups (Land Cruisers, Jeeps, to name a couple) do worry about this.
    <font color=blue>Parf</font color=blue>
    1984 K5 Jimmy 4x4 Sierra Classic
    6.2L diesel, 700R4
