Any one used POR 15 Products
Discussion in 'The Garage' started by Cmoe, May 29, 2004.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I'm looking at using it in many ways and wanted to hear any + and/or -.... Let me hear um......
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    did my frame and axles with por15, Great products
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    How long ago did you finish it? How's it holding up? What did you use over the POR-15? Chassis Coat, BlackCote or what? Can you send me some pic's?
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    have on protective clothing (gloves, paper mask, long sleeve shirt....) and safety glasses when you use this stuff - if it gets on you, the only thing that will get it off is time. read and follow the directions; its not your standard paint. imo - good stuff...
    POR post
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have heard nothing but good things about POR15. It has been discussed alot before and most all the stuff said is positive.
    Harley
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have used it and dont care for it. I have painted a few parts, along with my frame, and the floor board of my 2wd. It peeled off the frame. They say nothing takes it off, but brake fluid does. Another thing, if you want it to saty nice and gloss black, dont get your hopes up, it gets really dull and never gets shiny again. I think regular old Rustoleum is just fine!
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Did you go all the way to bare metal when you started?
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, I followed the instructions, exactly.
  9. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  10. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I use POR-15 on just about everything.
    The ONLY problems I've had is that it is not very tolerant of UV (sunshine) and it turns grey unless you cover it with some paint.
    POR-15 rocks. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif But you need to follow the application instructions or it will turn out to be an expensive mess. /forums/images/graemlins/blush.gif
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use POR15 a few times, It goes on like a stain and dries like engine enamle. It doesn't like new and clean steel. If you have bare metal you are supose to use their metal etch spray, never used that.I have used both the silver and black. Here is the inside of my hood in Por15 Black
    And yes it takes several days for it to wear off your hands and any clothing it gets on is permenante.
  12. dyeager535
    26,979
    I did my trailer with it, basically ignoring their instructions, kind of as a test to see how it would work.
    I used "expanded metal" on the trailer, so it is very hard to coat, hard to prep, and hard to cover well. The metal was as bare as it came from the metal supplier (probably had mill scale on it) but had been outside for a year or two, so some decent rust forming, but not really pitted, just a light surface coating.
    I just brushed the paint on thick so it would run into the places I missed, and left it at that.
    After about two years now, it is still sticking to the trailer no problem. No large flat surfaces though, so peeling issues probably aren't going to be seen in my case no matter what.
    Definitely affected by UV. It lightened up considerably (I think I got semi-flat black, or flat if thats all they offer, I know it isn't gloss) but that didn't seem to weaken it any.
    I don't personally believe it's a miracle paint, I've also tried one-step I think it was, and wasn't really impressed with it. I'm of the opinion that there really is no "magic paint", since every application is likely to be different in one way or another (humidity, temp, prep, application technique, material painting, etc.) results probably vary with every use.
    I'm not saying I don't like it, but I'm not sure that a rattle can, or another brush on product wouldn't work any better.
    For home-applied coatings (of any type) I think we still have a LONG ways to go before we are able to protect things like manufacturers can with ceramic coatings, urethane dips, and so on.
  13. b55baron
    b55baron Registered Member
    Jun 3, 2003
    39
    Marietta, Ga
    I've had good luck with it. I followed their directions and used their cleaner and metal prep. Then put on one coat of black, followed by gray (so that I could tell where I had been) and finished with chassis coat. I had better luck with a foam brush than with a bristle brush and it also sprayed well.
  14. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    I used the stuff on my frame and it worked great would recommend it to anyone that wants a paint coating that is gonna last this stuff is it . if u read their directions it says it will fade in the sun that is why u need to top coat it. I used their chassis coat black looks great just like it was painted at the factory
    Kevin
