Any one useing a Steering pump Cooler??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Feb 9, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey gang, anyone running a steering pump cooler.
    Are they nessisary on our rigs? I am replacing my fluid and was thinking about adding a cooler not only to keep the harware cooler but to also increase the fluid capacity.
    What do ya think, keep in mind I do use my rig for slow crawlin type of wheelin and I can remember during the summer that the steering box gets very warm on the trail..??
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  2. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
  3. konajoe
    Nov 15, 2000
    112
    7
    Yes, Perma-Cool makes some coolers with or without AN fittings. The lower temp will help to extend the seal, hose and pump life. You can check them out here.
    <A target="_blank" HREF=http://www.perma-cool.com/Catalog/Cat_page15.html>http://www.perma-cool.com/Catalog/Cat_page15.html</A>
    Hope this helps,
    KonaJoe
  4. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I'm running a hydraulic winch off of my power steering pump. I installed a basic transmission cooler in the return line and it has been working great for over three years.
    Steve Frisbie
    [image]http://albums.photopoint.com/j/View?u=1191682&a=8779286&p=28489343&Sequence=0&r[/image]
  5. Burt4x4
    6,854
    Cool thanks guys!
    So you can use one of thoes frame rail types made for tranies for the power steering? Does the hose size need to be the same?
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I just purchased a small power steering cooler just like KJ suggested. With the Rock Ram in the front, I thought it wouldn't hurt. My previous AGR box ran hot for some reason (could of been air).
    Shawn
    87 K5
    few mods[​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    The generation of Dodge trucks before the current one (don't know the years) have cool little tube&fin coolers right by the steering box. Looked to be like 3"x6"or so, very compact. You could probably find on in a junkyard.
    OR, you could get one of the tubes off a newer front-wheel-drive car. Just a long U-shaped hardline run across the grill/airscoop/whatever-they-call-it opening. My 93 Plymouth Laser and my 97 Mitsu Eclipse both have one of these. Just clean them out real good with some solvent and air, should be good!
    [​IMG] Semper Maintenance!
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I've been thinking of doing this also i'm not sure which one i'll use yet but i've found them on a ford maverck and the dodge p/u also there is a aluminum one that will hold about 1qt more. you can also try summit racing an jeg's both will have coolers for this.
    Drive it like you stole it !
  9. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    i've been meaning to ask someone with a hydraulic winch to see if it would be worth my money. I like the 10500 Mile Marker and the Ramesy platum 9500 (the new one as a bigger motor) if you get time let us or me know thanks
  10. 85m1009
    Jul 11, 2000
    718
    Missouri
    I've been running a Milemarker 10500lb 2 speed winch for over 4 years with no complaints. I am however going to convert to a dedicated belt driven hydraulic pump to speed it up for competition purposes. I know a lot of people don't care for hydraulic winches and there are pros and cons to each one. I stick to what has worked and will continue to work for my style of wheeling.
    Steve Frisbie
  11. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I run the return line front the box though the Trany cooler that was in my Replacment Rad. Befor doning this I replaced the pump every year or so and the fluid would get burnt after a hard day of wheeling. Now the fluid never gets burnt and the pump have stoped going though seals
  12. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got one off a 90 Dodge 1 ton. Never had a leak, and it was only 5 bucks at the local boneyard.
