Any one with 90 or 91 with cruise control
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Feb 4, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I bought a stock cruise control and I am trying to get it hooked up. I need to know where the black and yellow wires go. Iknow one is the speed sencer, but don't know where it is on the truck. On my 86 Sub. it is in the speedo, but it is mechanical and my Blazer is electroniclly controlled. any help is appreciated.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    If no one knows, does any one know where I can get a wiring diagram?
    Not FROM the people
  3. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    Try a chevy dealership I've gotten several wiring diagrams and part break-downs from them.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I know the HAynes manual has a good amount of wiring diagrams but they are pretty generic. Have you tried looking at them? Just a thought, till you come across something better. The biggest problem with them is they dont tell you where anything is located. OH, hell, its a long shot. Do you have an LMC catalog? Look through it, for the Cruise control, and see if it doesn't show you anything. I figured a few things out with the heater control looking at it. Sorry I couldnt help anymore.
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    ok, i've got an '89 fuelie, will that help? tell me where the two wires originate, i'll follow 'em till they disappear. or, i'll look at my shiton's manual. freakin thing's a piece of crap.
    excuse my manners.
    anyway, let me know if i can help, and when it gets a little lighter out there (i get to work early) i'll poke around abit.
    <font color=purple>delta9blazer</font color=purple>
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have the shop man. for the 1991 blazers.
    Let me know if you nead some info.
    brettmcox.coloradok5.com
    brettmcox@hotmail.com
  7. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    OK here goes: Find the cruise control box. It should be next to the iritating buzzer above the gas petel. Follow the wire harnest. you will have 3 gray wires break off to the break light switch. 1 pink wire that goes to the fuse panel. A small cluster of 4 wires that goes to the signal switch on the collum. That should leave only 2 wires. 1 black and 1 yellow. Where do those two go to? Thanks guys for all your help.
    Not FROM the people
  8. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Moven it up!
    Not FROM the people
